ᐅ Built-in Bathtub - Faucet
Created on: 20 Sep 2015 23:11
abertram
Hi,
we are having a surround built around our bathtub at the same height as the tub. Now I am looking for a suitable faucet. Rim-mounted faucets don't appeal to us; we prefer wall-mounted faucets. We like the Hansgrohe Focus series. Is there a way to extend wall-mounted faucets so that they reach over the built-up surround?
Maybe there are completely different options that we haven't considered yet?
Regards,
Alex
abertram
23 Sep 2015 10:13
The terms and conditions do not prohibit images, if I interpret them correctly?
Okay, so once again. This one is the one I have in mind:
Hansgrohe 31940000 Focus
I’m not fond of Axor and Metris.
____________________________________________________________
Hello abertram,
I have replaced the image with the product name.
I think everyone can agree on that.
Best regards, Musketier
FrankH
23 Sep 2015 17:07
abertram schrieb:
The terms and conditions don’t prohibit images, if I interpret them correctly?
If you took the photo yourself or can prove you have usage rights, otherwise it is a copyright violation and the image will most likely have to be removed by the moderators. Sometimes the internet is just difficult to manage without links.
Musketier23 Sep 2015 18:37
FrankH schrieb:
Sometimes the internet is difficult to use without links.
With the right search terms, it’s possible even without links and images.
But apart from pictures and links related to fittings, there hasn’t been a solution for the extension yet.
I would actually be more interested in a picture or drawing from abertram showing how he envisions it and what distances are involved.
If I understand correctly, the gap between the wall and the bathtub is too large. I can’t really imagine extending the fittings. It would probably make more sense to bring the connections closer to the bathtub from below. That would likely mean using built-in (concealed) fittings.
abertram
23 Sep 2015 23:03
Musketier schrieb:
I would be more interested in a picture or drawing from abertram showing how he envisions the whole thing and what distances are involved.
It will be difficult without being allowed to post images. And my drawing skills, well... :-(
Musketier schrieb:
If I understood correctly, the gap between the wall and the bathtub is too large. I can’t really imagine extending the faucet.
Yes, you understood correctly. It concerns the distance between the wall and the bathtub.
A wall-mounted faucet would also be an option. But the problem remains that the tub spout would need to be long enough to bridge the gap between the wall and the bathtub.
Kisska8623 Sep 2015 23:17
With modern bathtubs, the tub spout is integrated into the tub itself. So basically from underneath, directly into the tub at a kind of "lever" where you can open and close the drain plug at the bottom by turning it. Do you see what I mean?
abertram
23 Sep 2015 23:53
I had to think for a moment and look it up to understand what you meant. At Hansgrohe, the system is apparently called Exafill. But thanks, I hadn’t considered that. It really seems like a good solution.
