ᐅ Ideal Standard Bathtub Support Hotline
Created on: 10 Jan 2017 08:58
Stockheim
Stockheim
10 Jan 2017 08:58
we are currently starting to think about the bathroom.
For the bathtub, we want a 180 x 80 cm (71 x 31.5 inches) tub with a center drain and sufficient filling volume. There are tubs with relatively large external dimensions, but when you lie down, you can hardly fit both legs in the water.
We have now come across the Ideal Standard Hotline bathtub.
Based on the dimensions and description, it seems to have everything we need. I’m just a bit suspicious of the relatively low price...
So far, I have found the following criteria online:
- Sanitary acrylic (yes, we don’t want steel)
- Preferably reinforced rim and bottom
Can anyone say anything about this tub, or is there something hidden that makes it “low quality”?
Stockheim
Stockheim
10 Jan 2017 10:38
Since my link to the tub on the Ideal Standard website was removed, here is the exact designation:
Ideal Standard Hotline New Duo 180 x 80cm (71 x 31 inches)
10 Jan 2017 10:42
How expensive or affordable should it be at the authorized dealer?
Stockheim
10 Jan 2017 11:18
The bathtub costs around 200 euros.
10 Jan 2017 12:05
But that is just a base online price without the mounting bracket or anything else. Who will install it and provide a warranty?
Stockheim
10 Jan 2017 12:21
There are also complete packages available, including drainage, supports, and foam, for less than 300 euros.
Installation would then be a DIY job.
