ᐅ Creating a Plan for Insulating an Old Building – How to Proceed?
Created on: 30 Aug 2022 10:30
Tobibi
I’m currently trying to make a plan for how to best improve the insulation of our house. I hope I can write everything down clearly so that some of you might be able to give me tips or suggest different approaches.
We bought a large house from 1982, about 200 sqm (2,150 sq ft) of living space. There is an approximately 6-year-old heat pump for heating and hot water, and a small wood stove in the living room. The ground floor and first floor have underfloor heating, while three basement rooms and a converted room above the garage have radiators. These radiators have a separate heating circuit with their own flow temperature and are rarely used, actually not at all in the basement.
In the main bedroom on the first floor, the previous owner opened the ceiling a few years ago, creating a high space that goes up to the roof ridge. The roof was insulated at that time, but I don’t have any documentation on how well. The rest of the house remains in its original condition, so basically uninsulated.
The walls are solid brick. The wooden windows have double glazing. Many windows and the front door do not seal well, allowing noticeable drafts at some windows. The top floor ceiling is not concrete but made of joists, covered underneath on the first floor with drywall and boards on top. Between the joists, there appears to be rock wool insulation packed in.
We have a 9 kWp photovoltaic system with battery storage, which the previous owner also installed. As it currently stands, the electricity from the photovoltaic system cannot be used for the heat pump, only for other household electricity. There is a separate meter with a heating electricity contract. Surplus electricity is fed back into the grid.
I recently received the heating electricity bill, showing that from March 2021 to March 2022—one full year—we used about 12,500 kWh for heating and hot water, which I find quite high. I definitely want to take action, especially since electricity prices are rising sharply. I’m not an experienced DIYer, but I can assist and have very helpful father and father-in-law who have a lot of skills. So, some things could be done ourselves, although time is always a factor.
A no-brainer seems to be replacing the window seals and adjusting them so they close tightly again. I am already in contact with a company for this.
Next, I’m thinking about insulating the roller shutter boxes. I would probably get a company to do this as well.
I’m considering insulating the basement ceiling with insulation boards that can be glued or fixed with plugs. If there are instructions available, we would rather do that ourselves. Or should I focus on insulating the top floor ceiling or installing insulation between the rafters? Or both? Probably not at the same time—maybe one this year and the other in a year or two. What would be the better order?
Would it make sense to modify the photovoltaic system so that the electricity can be used for the heat pump? I would have to hire an electrician for that, which costs money. But then the electricity would be usable for heating, and there would be only one basic fee. On the other hand, the yield in winter is not very good, and I would lose the cheaper heating electricity tariff. I once tracked generated, fed-in, self-used, and purchased electricity over a longer period and basically concluded that the conversion might not be worthwhile. But now electricity prices are rising dramatically.
Insulating the facade and/or installing new windows is honestly too expensive for me right now. On the other hand, we will need to have the entire exterior repainted next year or the year after. That costs several thousand when done professionally, which would almost offset the cost of external wall insulation. But presumably, these two should go together—insulation and new windows—because doing only one is not sensible and could cause problems with condensation.
So, that turned out to be quite a long message. I hope it’s understandable. How would you proceed? If I forgot anything, just ask. I might also add a follow-up later.
Tobi
Tobi
chand198623 Mar 2024 16:23Adam2112 schrieb:
There are many sources online explaining how it works.How a theoretically unattainable value is practically achieved is nowhere explained. Neither online nor elsewhere.Are there really no simple experimental data? Why not?
Fill two identical thermos flasks with the same amount of boiling water. The only difference: one is coated. Measure the water temperature at times t1 - t10. Create a chart and upload it here. It's quick to do, so what’s the problem?
nordanney23 Mar 2024 16:46chand1986 schrieb:
How a theoretically unattainable value is practically achieved is not documented anywhere. Not online, nor elsewhere.
No simple experimental data available? Why not?
Fill two identical thermos flasks with the same amount of boiling water. The only difference: one is coated. Measure the water temperature at times t1 - t10. Create a chart and upload it here. It’s easy to do, so what’s the problem?There is plenty available online. Just google it.
I just uploaded thermal camera images; the laws of physics apply everywhere, so based on the data I provided, you can even calculate the U-value of the wall.
No, I also can’t find anything that would explain the effect. But I found the product Bauter, which actually looks even better. They also have their own energy consultant included, which makes it eligible for KfW. It should basically do the same as PScoat but seems to be "better."
nordanney23 Mar 2024 20:15Cronos86 schrieb:
But I found the Bauter product, which actually looks even better.Yep. Bauter Outside. But you better not check the official product description…
It just says "paint"… LOL
By the way, it also happens to come from Poland. There is a similar product from the company Isofiretec, founded just six months ago. They promote the product too – but without certificates or any other downloadable documentation.
The worst part is, I would even wish for these products to work so I could just paint my house and everything would be fine.
And the solution to the energy crisis fails only because Adam can’t convince us. Sad.
But a “check it out yourself” or “watch this meaningless video” just isn’t enough anymore. If you want to sell miracle products, you need to be able to prove the miracles empirically. So Adam, please provide an experiment that is reproducible! Not just a statement like “the wall feels warmer.”
