ᐅ Creating a Plan for Insulating an Old Building – How to Proceed?
Created on: 30 Aug 2022 10:30
Tobibi
I’m currently trying to make a plan for how to best improve the insulation of our house. I hope I can write everything down clearly so that some of you might be able to give me tips or suggest different approaches.
We bought a large house from 1982, about 200 sqm (2,150 sq ft) of living space. There is an approximately 6-year-old heat pump for heating and hot water, and a small wood stove in the living room. The ground floor and first floor have underfloor heating, while three basement rooms and a converted room above the garage have radiators. These radiators have a separate heating circuit with their own flow temperature and are rarely used, actually not at all in the basement.
In the main bedroom on the first floor, the previous owner opened the ceiling a few years ago, creating a high space that goes up to the roof ridge. The roof was insulated at that time, but I don’t have any documentation on how well. The rest of the house remains in its original condition, so basically uninsulated.
The walls are solid brick. The wooden windows have double glazing. Many windows and the front door do not seal well, allowing noticeable drafts at some windows. The top floor ceiling is not concrete but made of joists, covered underneath on the first floor with drywall and boards on top. Between the joists, there appears to be rock wool insulation packed in.
We have a 9 kWp photovoltaic system with battery storage, which the previous owner also installed. As it currently stands, the electricity from the photovoltaic system cannot be used for the heat pump, only for other household electricity. There is a separate meter with a heating electricity contract. Surplus electricity is fed back into the grid.
I recently received the heating electricity bill, showing that from March 2021 to March 2022—one full year—we used about 12,500 kWh for heating and hot water, which I find quite high. I definitely want to take action, especially since electricity prices are rising sharply. I’m not an experienced DIYer, but I can assist and have very helpful father and father-in-law who have a lot of skills. So, some things could be done ourselves, although time is always a factor.
A no-brainer seems to be replacing the window seals and adjusting them so they close tightly again. I am already in contact with a company for this.
Next, I’m thinking about insulating the roller shutter boxes. I would probably get a company to do this as well.
I’m considering insulating the basement ceiling with insulation boards that can be glued or fixed with plugs. If there are instructions available, we would rather do that ourselves. Or should I focus on insulating the top floor ceiling or installing insulation between the rafters? Or both? Probably not at the same time—maybe one this year and the other in a year or two. What would be the better order?
Would it make sense to modify the photovoltaic system so that the electricity can be used for the heat pump? I would have to hire an electrician for that, which costs money. But then the electricity would be usable for heating, and there would be only one basic fee. On the other hand, the yield in winter is not very good, and I would lose the cheaper heating electricity tariff. I once tracked generated, fed-in, self-used, and purchased electricity over a longer period and basically concluded that the conversion might not be worthwhile. But now electricity prices are rising dramatically.
Insulating the facade and/or installing new windows is honestly too expensive for me right now. On the other hand, we will need to have the entire exterior repainted next year or the year after. That costs several thousand when done professionally, which would almost offset the cost of external wall insulation. But presumably, these two should go together—insulation and new windows—because doing only one is not sensible and could cause problems with condensation.
So, that turned out to be quite a long message. I hope it’s understandable. How would you proceed? If I forgot anything, just ask. I might also add a follow-up later.
Tobi
KarstenausNRW
27 Dec 2022 08:24
karl.jonas schrieb:
Contradiction?
Sort of. The CE marking is carried out by the manufacturer themselves. However, they must comply with certain requirements, such as how to perform the testing.
There is also a checklist from the DIBt – which I have posted before – detailing exactly how the CE marking must appear. And that’s where the trouble starts for the manufacturer, as not even the mandatory font is used. Not to mention other issues.
In addition, there should be a Declaration of Performance for the product if it is covered by an EU harmonized standard, for example. This includes testing of thermal conductivity according to some DIN standard. This Declaration of Performance is also missing for the product – the builder MUST have this declaration, for example, to comply with regional building regulations.
Once again: Without proper evidence, I could formally equate a latex paint stirred by virgins under a full moon with this product. At least on paper. Currently, the product is marketed in CZ/PL/Thailand for a thermal conductivity class WLG 32 (e.g. EPS or similar) (also with correct CE marking after initial testing). That seems more realistic.
CE-Kennzeichnung Checkliste: Dokument mit CE-Symbol und Tabelle
Screenshot eines Textdokuments zur Leistungserklärung für Bauprodukte
Dämmmaterial: Temperaturbereich -200 bis +200 °C, Kondensationsschutz.
Tabelle mit Wasserdampf-Durchgangskoeffizient und Bauteiltestwerten der Gebäudehülle
Buschreiter
27 Dec 2022 08:47
Then the question arises with a thermal conductivity of 0.032 W/(m·K), how I would manage to secure 14cm (5.5 inches) of that :p
Cronos86
27 Dec 2022 09:02
Holding the structure worries me less. But at about €38 per square meter for a 3 mm (0.12 inch) layer thickness, I definitely don't want to pay for 14 cm (5.5 inches). 😱
Buschreiter
27 Dec 2022 11:32
The documents from the sales department have arrived and have been forwarded to my advisor. Let's see what he says.
chand1986
27 Dec 2022 12:15
The most fascinating thing about the human brain, to me, is its ability to deceive itself.
I’m imagining graduating from a mechanical engineering program because I don’t understand the basics, and then convincing myself that I dropped out because “the others” just can’t think critically…
Only to later try to market a product that doesn’t even list the real specifications on its online sales pages—the very specs I’m lying about here online.
And then I actually believe all of it myself.
It’s like being dead. A problem only for others. (I always have my cynical phase after Christmas)
KarstenausNRW
13 Jan 2023 10:00
@Buschreiter
Have you already received any feedback on the miracle product from the energy consultant?
