ᐅ Creating a Plan for Insulating an Old Building – How to Proceed?
Created on: 30 Aug 2022 10:30
Tobibi
I’m currently trying to make a plan for how to best improve the insulation of our house. I hope I can write everything down clearly so that some of you might be able to give me tips or suggest different approaches.
We bought a large house from 1982, about 200 sqm (2,150 sq ft) of living space. There is an approximately 6-year-old heat pump for heating and hot water, and a small wood stove in the living room. The ground floor and first floor have underfloor heating, while three basement rooms and a converted room above the garage have radiators. These radiators have a separate heating circuit with their own flow temperature and are rarely used, actually not at all in the basement.
In the main bedroom on the first floor, the previous owner opened the ceiling a few years ago, creating a high space that goes up to the roof ridge. The roof was insulated at that time, but I don’t have any documentation on how well. The rest of the house remains in its original condition, so basically uninsulated.
The walls are solid brick. The wooden windows have double glazing. Many windows and the front door do not seal well, allowing noticeable drafts at some windows. The top floor ceiling is not concrete but made of joists, covered underneath on the first floor with drywall and boards on top. Between the joists, there appears to be rock wool insulation packed in.
We have a 9 kWp photovoltaic system with battery storage, which the previous owner also installed. As it currently stands, the electricity from the photovoltaic system cannot be used for the heat pump, only for other household electricity. There is a separate meter with a heating electricity contract. Surplus electricity is fed back into the grid.
I recently received the heating electricity bill, showing that from March 2021 to March 2022—one full year—we used about 12,500 kWh for heating and hot water, which I find quite high. I definitely want to take action, especially since electricity prices are rising sharply. I’m not an experienced DIYer, but I can assist and have very helpful father and father-in-law who have a lot of skills. So, some things could be done ourselves, although time is always a factor.
A no-brainer seems to be replacing the window seals and adjusting them so they close tightly again. I am already in contact with a company for this.
Next, I’m thinking about insulating the roller shutter boxes. I would probably get a company to do this as well.
I’m considering insulating the basement ceiling with insulation boards that can be glued or fixed with plugs. If there are instructions available, we would rather do that ourselves. Or should I focus on insulating the top floor ceiling or installing insulation between the rafters? Or both? Probably not at the same time—maybe one this year and the other in a year or two. What would be the better order?
Would it make sense to modify the photovoltaic system so that the electricity can be used for the heat pump? I would have to hire an electrician for that, which costs money. But then the electricity would be usable for heating, and there would be only one basic fee. On the other hand, the yield in winter is not very good, and I would lose the cheaper heating electricity tariff. I once tracked generated, fed-in, self-used, and purchased electricity over a longer period and basically concluded that the conversion might not be worthwhile. But now electricity prices are rising dramatically.
Insulating the facade and/or installing new windows is honestly too expensive for me right now. On the other hand, we will need to have the entire exterior repainted next year or the year after. That costs several thousand when done professionally, which would almost offset the cost of external wall insulation. But presumably, these two should go together—insulation and new windows—because doing only one is not sensible and could cause problems with condensation.
So, that turned out to be quite a long message. I hope it’s understandable. How would you proceed? If I forgot anything, just ask. I might also add a follow-up later.
Tobi
KarstenausNRW
23 Dec 2022 14:22
Buschreiter schrieb:
Well… now what? What to do? I’m struggling with the usual insulation thicknesses for the basement ceiling…
As always, when low insulation thickness and easy installation (adhesive bonding) are desired, aluminum foil-faced PUR foam is a good choice.
Adam2112
23 Dec 2022 16:08
Well... now what? What to do? I'm struggling with the usual insulation thickness for the basement ceiling...
I have already made a recommendation. You could try starting with a small bucket. They might sell you two or three liters as a sample to convince the forum here. That is enough for about 6-10m² (65-108 ft²). As I said, I once left the roll to "dry" on a wall after application, and even then the effect was noticeable. Heat simply doesn't pass through.
Cronos86
23 Dec 2022 16:42
Adam2112 schrieb:
I’ve already given a recommendation here. You can start with a small bucket. They might sell you two or three liters as a sample to convince the forum. That’s enough for 6–10m² (65–108 sq ft). As I said, I once "dried" the roll on a wall after application, and even then the effect was noticeable. No heat passes through it.
You still haven’t explained why PScoat markets the same product with different thermal conductivity values?
Adam2112
23 Dec 2022 17:13
Mistakes happen everywhere. You can see this in the scientific documentation. Everyone is free to replicate the test setup. I have shared it here in post #35. Your disbelief doesn’t change the fact that it works.
But you probably also believe that airplanes don’t actually fly, because physically this wasn’t possible 100 years ago.
SoL
23 Dec 2022 17:21
Adam2112 schrieb:
Mistakes happen everywhere. This can be found in the scientific literature. Everyone is free to replicate the experimental setup. I have posted it here. #35. Your disbelief doesn’t change the fact that it works.
But you probably also believe that airplanes don’t actually fly because physics made that impossible 100 years ago.
It’s the other way around: You want to sell something but fail to provide proof and don’t explain inconsistencies. Your answer is just "Buy a little from my shop and try it out." No, first you have to deliver, then it can become attractive to us.
As it stands, it remains snake oil, as Americans would say.
Snake oil (from English "snake oil") is the term for a product that has little or no real function but is marketed as a miracle cure for many problems.
Adam2112
23 Dec 2022 17:31
SoL schrieb:
It’s the other way around: You want to sell something but fail to provide evidence and don’t clarify inconsistencies.
Your response is just "Buy a little from my shop and try it out." No, you have to deliver first, then it can become attractive for us.
As it stands, it remains snake oil, as the American expression goes.
Anyone open and interested will request documentation, watch the numerous videos on AZ’s YouTube channel, try it out, and see that it works. Like with any innovation, there will always be more people refusing than trying. It was the same back in the day with cars versus horses. I can’t help you. The barrier to entry is low, anyone can convince themselves, and if you don’t want to, sorry. That person will just have to hang carpets on their walls.
