ᐅ Insulation of the foundation base with thermal conductivity class 025 (WLG 025)
Created on: 25 Jun 2021 10:32
neo-sciliarN
neo-sciliar25 Jun 2021 10:32Hello everyone,
according to the building plan, I am supposed to insulate the edge of the foundation slab (plinth) with 6cm (2.4 inches) WLG 025 insulation.
1.) I can’t find any such boards. Most only have WLG 035. Do you have any tips on where I can get these?
2.) Should they be fully glued, fixed with dowels, or both?
sciliar
sciliar
nordanney25 Jun 2021 10:49There are options, for example, from Synthos or Austrotherm (XPS Premium). However, with a thermal conductivity class (WLG) of 27 instead of 25.
nordanney25 Jun 2021 10:55Burying PUR in the ground? Not the standard material.
neo-sciliar25 Jun 2021 10:55Hi,
I also found the PUR perimeter insulation 025, but the description says "for interior insulation only."
Question: can I replace 6cm (2.4 inches) 025 with 8cm (3.1 inches) WLG 035?
nordanney25 Jun 2021 10:59neo-sciliar schrieb:
Question: Can I replace 6cm (2.5 inches) 025 with 8cm (3 inches) WLG 035? That needs to be calculated. XXX XXXXX
