Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Tom1978
29 Nov 2021 18:11
Work continues. Precise site marking is complete. Foundation work is underway. Strip footings will be installed tomorrow.
Construction site in the field: earthworks, pipes, wooden markers, sand piles, forest in the background.
Excavation with excavator, two workers in safety vests, pipes and sand piles on the construction site.
Construction site with soil, orange PVC pipes, excavation, earth piles and forest in the background.
In der Ruine29 Nov 2021 18:22
Tom1978 schrieb:
The strip foundations are coming tomorrow.
Is there no geotechnical work planned for a frost protection edge beam? How deep will the strip foundations be installed?
Tom1978
29 Nov 2021 18:39
In der Ruine schrieb:
Is there no underground construction for a frost protection footing? How deep do the strip footings go?
This is how it should look (more words)
Cross-section of a wall structure with insulation, foundation, reinforcement, waterproofing, and exterior plaster
Tolentino29 Nov 2021 22:56
They will probably add aggregates. This way, the reaction during curing will still generate some heat. It can even work down to -5°C (23°F).
Tom1978
30 Nov 2021 05:32
Tolentino schrieb:
They will probably add aggregates. Then the reaction during setting generates some additional heat. It works even down to -5°C (23°F)
Yes. I spoke with the groundworks contractor. Down to -5°C (23°F) is not a problem. They will put insulation mats on top, so the heat released by the concrete stays retained.
Tom1978
1 Dec 2021 18:09
The concrete slab will be poured on Friday. I’m looking forward to it 😎
Construction site: foundation slab with pink insulation, reinforcement mesh, pile of sand in the background.
Foundation slab with steel reinforcement mesh on a building site, forest in the background.
Foundation slab on pink insulation boards with reinforcement mesh, wooden edge formwork and earthworks.
