ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
KfW 55 standard
Electricity consumption 9 kWh
COP 3.88
halmi
23 Nov 2021 08:07
@Hausbau 55 cost around 200-250€ (220-275 USD). The meter is calibrated, although that is not the main issue here. The meter is an
Eltako DSZ15D-3x80A
guckuck2
23 Nov 2021 08:51
Wow, 3x80A is a bit too much, isn’t it? 🙂
Just looking at the device, you can find one for around €40. The electrician simply connects it between the phases of the heat pump on a DIN rail.
Isn’t that a funding requirement nowadays? I think for us it was the BAFA funding that required it anyway.
RotorMotor
23 Nov 2021 09:06
guckuck2 schrieb:
Isn’t that no longer a requirement for subsidies nowadays? I think with us it was the BAFA subsidy that required it anyway.
As far as I know, it is sufficient if the heat pump records it independently.
HarvSpec
23 Nov 2021 09:20
We (3 people, 180 m² (1,938 sq ft), renovated 1960s building, living room temperature at 22-23°C (72-73°F), bathroom ≥23°C (73°F)) currently use 11-12.5 kWh per day. Outside temperature is around ±5°C (41°F) in the evenings, and the heater is often on then.
halmi
23 Nov 2021 09:34
guckuck2 schrieb:
Wow, 3x80A seems a bit oversized, doesn't it? 🙂
Just looking at the device itself, you can find one for around 40€. The electrician simply mounts it on a DIN rail between the phases of the heat pump.
Isn't that a requirement for funding nowadays? I think the BAFA subsidy required it in our case.
The electrician installed it like that, so it doesn't really matter.
netuser
23 Nov 2021 09:59
Isn't that still a prerequisite for funding nowadays? I think for us it was the BAFA funding that required it anyway.
BAFA does require a meter, but the internal one installed by the manufacturer (not calibrated) is sufficient.
