ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
Heated area 200m2 (2,153 sq ft)
KfW 55 standard
Mechanical ventilation with heat recovery
Current outdoor temperature 6°C (43°F)
Heating energy consumption including hot water 35 kWh
Electricity consumption 9 kWh
COP 3.88
Malz1902
23 Nov 2021 12:22
So, with an outdoor temperature of 2°C (36°F), a heating curve of 0.1 is too low, the bathroom temperature dropped to only 21.3°C (70.3°F).
I have now slightly increased it again.
I'm curious to see what will happen when it gets to 0°C (32°F) or colder.
HarvSpec
23 Nov 2021 12:59
Since this winter, we have had an additional infrared heater in the bathroom because we couldn’t install enough underfloor or wall heating. Instead of running the entire system just for one room, this works great. We use it for about half an hour in the morning and evening, and it feels comfortably warm.
face2623 Nov 2021 13:06
Malz1902 schrieb:
So, at an outdoor temperature of 2°C (36°F), a heating curve of 0.1 is too low; the bathroom temperature has dropped to only 21.3°C (70.3°F).
I’m curious to see what happens when it gets to 0°C (32°F) or colder.
I think it’s tricky to adjust the heating curve too much when it’s above freezing. The impact on the flow temperature is naturally much less significant at warmer outdoor temperatures. You’re not only changing the slope but also affecting the base point.
If you’re unlucky, you might end up increasing the heating curve even more when it’s really below freezing. In that case, raising the base point could have been a better option. Also consider the term “parallel shift” here.
Dennis89
29 Nov 2021 20:49
Today it will be around 14 kWh. Heat pump currently at 3 degrees Celsius (37°F). Compressor has been running continuously at 25 Hz (600 W) for 24 hours. Don’t you also think that 600 watts is a bit too much? I just can’t get the compressor to run at 20 Hz.-.-
Daily overview: bar chart of hourly kWh consumption on November 29; cost €3.21, consumption 12.89 kWh
face2629 Nov 2021 20:53
Dennis89 schrieb:
Today the consumption is around 14 kWh. Outdoor temperature currently 3°C (37°F). The compressor has been running at 25 Hz (600 W) continuously for 24 hours. Don’t you think 600 watts is a bit too much? I just can’t get the compressor to run at 20 Hz -.-
I don’t understand the approach. Is the house too warm?
guckuck2
29 Nov 2021 20:54
Dennis89 schrieb:
Today the energy consumption is about 14 kWh. Outside temperature currently 3°C (37°F). The compressor has been running at 25 Hz (600 W) continuously for 24 hours. Don’t you think 600 watts is a bit too much? I just can’t get the compressor to run at 20 Hz -.-
[ATTACH alt="lwwp-aktueller-verbrauch-und-daten-543176-1.jpeg"]67572[/ATTACH]
If the compressor runs continuously and the house reaches the desired temperature, everything is working correctly. Why do you want to draw less power? To do that, you would probably need to set a lower indoor temperature or somehow magically increase the efficiency.
