ᐅ Window tolerances: frame dimensions and squareness
Created on: 1 Mar 2021 14:45
Parasolid
Parasolid
1 Mar 2021 14:45
can someone tell me if there is a general tolerance for windows? Not the rough opening.
Specifically, I am concerned about squareness. I have a plastic lift-and-slide door where the vertical frame is not at a right angle. When the door is open, this is quite noticeable. At the bottom, the glass is hidden behind the fixed part, and at the top, there is almost 3 cm (1.2 inches) of visible gap.
Is this considered a defect? Or do I have to accept it?
Thank you very much and best regards
11ant1 Mar 2021 16:33
Parasolid schrieb:
At the bottom, the glass disappears behind the fixed element, at the top I have almost 3cm (1.2 inches) of clear view.
Could you take a photo?
Parasolid
4 Mar 2021 09:45
Maybe it’s “only” 2 cm (0.8 inches), but that’s still too much?
Tolentino4 Mar 2021 09:48
Yes, it looks awkward, but if everything seals properly, it is probably a minor defect.
I mean, 2cm (1 inch) over 2m (6.5 feet) – and it's likely even higher, right? – is only about a 1% deviation... Annoying, but I don’t think you can achieve much with it...
I
icandoit
4 Mar 2021 10:02
Is the window crooked or is it the frame?
2 or 3 cm (about 1 inch) with the window closed means it will never be airtight, right?
11ant4 Mar 2021 11:52
icandoit schrieb:
Is the window crooked or the frame?
2 or 3 cm (1 inch) with the window closed can never be sealed properly, right?
I also think it is so crooked that it might be intentional: is the reveal so uneven that the window fitter or measurer deliberately passed it on this way, preferring to fit the frame directly to the reveal rather than cover the gap with a noticeable wedge-shaped trim?
