Hello!
I'll start.
KfW 55 standard
Electricity consumption 9 kWh
COP 3.88
I'll start.
KfW 55 standard
COP 3.88
Bookstar schrieb:
Analyzed the last 24 hours today:
Outside temperature around 1 degree Celsius (34°F)
Required heat quantity in the last 24 hours: 90 kWh (water and heating)
Electricity consumption: 24 kWh
90 / 24 = COP 3.75.
It’s not completely unreasonable, but it’s also not really good for a KfW55 house with a state-of-the-art air source heat pump. I would like to see it above 4.x.
I will perform a new hydraulic balancing when it gets colder, as I suspect there is a short circuit causing unnecessary energy loss.
Otherwise, everything is already optimized as far as possible. 24 kWh for the last 24 hours is really not good. I will reset my heat pump and monitor the next 24 hours again.
Yesterday I had 21.6 kWh overall for 24 hours.
This cannot be explained by 2 degrees Celsius (36°F) higher flow temperature and heating the basement.
Alessandro2 Feb 2021 10:39Isn't it good? 😱
Alessandro schrieb:
Is that not good? 😱What was the consumption for @halmi yesterday?Bookstar schrieb:
No, in my opinion it’s not good either. I would expect a value between 17 and 21 kWh. That means an efficiency improvement of about 20%. How are your TACOs set for each heating circuit? Have you already posted the table/data here?
Zaba12 schrieb:
How are your tacos set for each heating circuit? Have you already posted the table/data here?No, that’s exactly what I need to work on now. I’m preparing a table with a) theoretical calculation b) current settings c) target stateThen I will recalibrate everything.
