ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
KfW 55 standard
Electricity consumption 9 kWh
COP 3.88
halmi
20 Nov 2020 20:35
Is the electricity consumption including hot water?
From October 18th until today, November 20th, we used a total of 290 kWh including hot water for four people.
KfW55 standard, solid construction, controlled mechanical ventilation, and 218 m² (2340 sq ft) of heated floor area.
Blauer Eltako DSZ15D-3x80A Zähler mit Display in Wandmontage.
Blauer digitaler Stromzähler an der Wand mit Display und zwei Knöpfen rechts.
truce20 Nov 2020 21:00
Consumption in our home since 01.09.2020 including hot water:
Electricity 218 kWh (but with a ground-source heat pump)
The energy-demanding months are still ahead... (Dec-Feb)
Bookstar
20 Nov 2020 21:08
From October 18 to today, November 20, we used a total of 290 kWh including hot water for four people.
KfW 55, solid construction, controlled ventilation, and 218 m² (2341 sq ft) heated area.
Yes, including hot water. We used 430 kWh, same size and also KfW 55. But it really depends a lot on the location and heating habits.
Bookstar
20 Nov 2020 21:10
truce schrieb:
Consumption for us since 01.09.2020 including hot water:
The energy-consuming months are still to come (Dec-Feb)
That is extremely low, even for ground-source. We need about 3 kWh on average just for hot water.
halmi
20 Nov 2020 21:19
Bookstar schrieb:
Yes, including everything. We used 430 kWh, same size and also KfW55 standard. But it really depends a lot on the location and heating habits.
Our house is rather warm, at least 22 degrees Celsius (72°F), with bathrooms and living areas at 23 degrees Celsius (73°F). The average outside temperature is -13.2 degrees Celsius (8°F). We have already had a few nights with frost.
blackm8820 Nov 2020 21:19
Our air-to-water heat pump has consumed 305 kWh of electricity since September 1, 2020. Hot water + underfloor heating
