ᐅ Single-family house, 175 sqm without a basement—too large?
Created on: 15 Apr 2020 10:02
Drasleona
Hello everyone
I would also like to hear your opinion on our current design.
Plot size: 507 sqm (5455 sq ft)
Slope: yes, about 4 m (13 ft) difference in height over a length of 30 m (98 ft)
Floor area ratio (FAR): 0.4
Site occupancy index: 0.8
Building envelope, building line and boundary: 3 m (10 ft) to the street
Edge building: allowed for garage/carport
Number of floors: max. 2 full stories
Roof type: anything except flat roof
Style: any
Orientation: any
Maximum heights/limits: ridge height max. 12 m (39 ft), wall height max. 10 m (33 ft)
Style, roof type, building type: gable roof
Basement, floors: no basement, almost 2 full stories (knee wall 1.86 m (6 ft))
Number of occupants, age: 3 people, 1 teenager, 2 adults
Space requirements ground floor / upper floor: approx. 175 sqm (1880 sq ft)
Office: home office
Guest bedrooms per year: rarely 2 guests
Open or closed architecture: rather open, airy, including open kitchen
Balcony, roof terrace: no to both
Garage, carport: double carport planned later
Who designed it: put together myself
What do you like most? Why?
- Direct access from the bedroom through the dressing room to the bathroom
- Cloakroom niche keeps dirty shoes outside the main passage area
- Floor-to-ceiling windows for lots of light
- Straight staircase, looks modern, easier to walk on than a spiral one and better for accessibility later (stairlift)
- Very spacious living/dining/kitchen area (though perhaps too large?)
- Pantry with everything easily accessible on open shelves
What do you dislike? Why?
- Huge waste of space in the hallways
Why did the design turn out this way?
I saw a similar layout in a townhouse that I really liked at first glance. We want a generous living feel with large window areas.
Since we are planning without a basement, an extra room upstairs was created for storage, guest room, and workshop space.
Important: the bathroom layout is not really planned yet. I have inserted my first idea there but I know it is still far from a “good idea.” For now, the focus is on the basic room layout. The windows are currently more of an idea than fully thought through.
What is the most important / fundamental question about the floor plan summarized in 130 characters?
- Do you see a way to reduce hallway space despite having a straight staircase?
- What is your overall impression of the design?
Style: any
Orientation: any
Office: home office
Drasleona schrieb:
The base model is the Solitäre 165, but on the website, you can only find various designs based on it (including extensions). It's a pity, because this makes it difficult to get an impression of how the original model would look as a building form. All the images available make me wonder whether one has to be a bit of a trickster to speculate about any connection between Schwabenhaus and Bien-Zenker. After all, they are associated with Living Haus, which is effectively a subsidiary.
In any case, you have clearly "freed" your version quite extensively from this base model — right down to the straight staircase now. What seems most important to me is that it looks functional. Whether I am convinced by the way it fits into the terrain, I’m not quite sure yet. Your descriptions don’t fully convince me; I would prefer to see a site plan with elevation points.
Drasleona23 Apr 2020 21:37The site planning is still quite a challenge, and I don’t want to sugarcoat that. However, the property extends along the slope for a considerable length (a good 32m (105 feet)). So, we assume that we can build the carport, house, and terrace all at the same level without issues. How to proceed with the lower part, where the slope continues to descend in the garden, is still unclear. The local council itself isn’t quite sure yet either and is currently under pressure from many builders who need to find practical solutions for managing the elevation differences.
Do you see the problem mainly in terms of costs or the overall feasibility? I’m already worried that we might significantly underestimate the financial aspect, but I’m not sure how else to handle it...
Drasleona23 Apr 2020 22:0811ant schrieb:
I hope for my own peace of mind that you’re not getting the idea that a straight, single-flight staircase would make anything easier. For floor plans with edges shorter than 12m (39 feet), you wouldn’t even need to look—single-flight straight staircases are, like symmetry dogma, though at least these two notions only weakly overlap, a prime example of a space hog. I’m currently following your advice and reading the other topic, and I came across this post from you. Do you also find the staircase in my floor plan that bad?
Drasleona schrieb:
Do you also find the staircase in my floor plan that bad? No. The fact that it still works in your case is because, as I already mentioned, you are not trying to squeeze “thirteen wishes into twelve square meters.” Probably due to the interaction with the high knee wall, things are working out this time that normally wouldn’t fit. But this is something known from nature as well: contrary to theory, bumblebees can actually fly. So your staircase is, in a way, an exception to the rule.
Drasleona24 Apr 2020 15:34That looks like about a 1.85 m (6 feet) height difference around the house area. Based on the now well-known and assumed opinion of 11ant, this is a clear indication of a basement. However, without placing the specific house within the property, it is not possible to determine what kind of terrain shaping this would imply at which location.
