Created on: 27 May 2019 10:48
goalkeeper
goalkeeper11 Mar 2020 22:32However, the picture is very misleading. Since the subcontractor from Netze BW has not yet closed the opening for the house connections, the screed sand could not be unloaded on our property. Otherwise, all other builders had to cover their streets with protective sheets to keep the road intact.
Therefore, the street is still in its original condition because everyone is unloading their materials somewhere on various properties. This is not a problem as long as no one else needs the space. We don’t have the kind of small disputes over “that’s my 5cm (2 inch) piece of land” like in other developments. Everyone finds the space they need – the rest is managed among the tradespeople.
goalkeeper schrieb:
the screed sandThat small amount of screed sand won’t harm the paving. The heavy-duty traffic will crush the paving. Since the development authority has planned that everyone may either raise their plot by about 150 cm (5 feet) or build a basement, quite a few trucks will be driving over it. You could ask the local authorities what expected service life they assume under these specific conditions.However, in this area, it is simply common practice to finish the roads first and then start building.
I constantly see this in new housing developments. If it were such a huge mistake and every time the adjacent streets had to be completely redone immediately after the construction phase, someone probably would have thought about it by now.
If the subbase is properly compacted, the roads should be able to withstand it.
goalkeeper12 Mar 2020 13:31Our local civil engineer will be preparing the area around the house in the next few days by spreading and leveling the 110m3 (145 cubic yards) of soil already on site at a reasonable price.
Advantage: there are about 80 cubic meters (105 cubic yards) of compactable excavated material on the neighboring property that we can take for free. Otherwise, all the levels will be set to ensure they fit properly for the paving contractor later on.
On the neighbor's side (the other end townhouse), about 1.50m (5 feet) will need to be sloped. Whether this can remain as is if they excavate their basement will have to be determined later.
