ᐅ Is an emergency override for blinds on the upper floor strictly necessary?
Created on: 23 Feb 2020 15:37
Golfi90
Hello everyone.
Today we visited our soon-to-be neighbors and took a look at their house.
I noticed a manual crank (in addition to the electric switch) on a shutter on the upper floor.
Our neighbor said that such an emergency opening is mandatory in Lower Saxony!
However, we have not planned for something like that. Or rather, our general contractor hasn’t!
Are there regulations on when such an emergency opening is required and when it is not?
F
freakbetty23 Feb 2020 20:51The second emergency exit is regulated in the Lower Saxony Building Code (Niedersächsische Bauordnung) under § 33. "For each unit of use with at least one habitable room, there must be at least two independent emergency exits to the outside on each floor. The first emergency exit for a unit of use according to paragraph 1 sentence 1, which is not on the ground floor, must lead via a required staircase (§ 34 paragraph 1 sentence 2). The second emergency exit can either lead via another required staircase or to a location within the unit that can be accessed by the fire department’s rescue equipment. A second emergency exit via a location accessible to the fire department is acceptable as long as there are no concerns regarding the suitability of the escape route for rescuing people."
Because of these concerns, most people install a mechanical opening option.
pffreestyler24 Feb 2020 08:11A not entirely serious question: when it comes to burglary protection, it is always said that roller shutters do not provide security because they can be removed within a few seconds. So why is the same effort made for fire protection? Operating the crank probably takes about as long as applying a bit of force to the roller shutter...
Grantlhaua24 Feb 2020 08:22guckuck2 schrieb:
You need a second one. The stairs are the first.I am really curious how that would work? The window is usually 4m (13 feet) above the ground.
Grantlhaua schrieb:
I would be really curious how that’s supposed to work? The window is usually about 4m (13 feet) above the ground.Well, it’s quite simple—the fire department arrives with the proper equipment for evacuation. If the turntable ladder can’t reach a certain spot, you would need to provide a second staircase, external ladder, or something similar.
In a daycare center, I once saw a slide used as a second escape route.
pffreestyler schrieb:
Operating the crank probably takes about as long as applying some force to the roller shutter... And now do you expect your child or the firefighter to use force against the roller shutters on the house if you are lying on the ground floor, unresponsive?
Grantlhaua24 Feb 2020 10:02ypg schrieb:
And now you expect your child or the firefighter to use force against the shutters on the house when you are lying on the ground floor and unresponsive?But a 3-year-old child will hardly be able to roll up the shutters.
