ᐅ Suggestions for Improving the Floor Plan of a House in a Green Environment
Created on: 5 Aug 2019 17:12
Cayman
After initial discussions with the architect, we are still not 100% satisfied, so I would like to ask the forum for suggestions. At the moment, I feel like I’m at a dead end with no way out, as every idea does not achieve the desired effects. The idea of having a secondary apartment is generally not bad, as housing is very scarce in our area.
Development Plan/Restrictions
Plot size: 4000 sqm (1 acre), of which 800 sqm (0.2 acres) is buildable
Slope: slight north-facing slope (approx. 1 m (39 inches) over 20 m (22 yards))
Roof type: flat roof
Architectural style: Bauhaus
Development plan attached
Style, roof type, building type: flat roof, modern
Basement, floors: basement, ground floor, first floor
Number of people, age: two adults, a child on the way, minimum 2 children
Space requirement ground floor, upper floor: 175 sqm (1880 sq ft)
Office: home office
Guest bedrooms per year: 15
Conservative or modern building method: modern
Kitchen island
Number of dining spaces: 8
Fireplace: yes
Balcony, roof terrace: possible, not planned
Carport
Utility garden
Planned by:
-architect
What do you like most? Why?
the open design, the first floor is perfect. Views from the living and dining areas as well as from the kitchen into the greenery
What don’t you like? Why?
Kitchen next to the staircase, pantry on the south side, staircase on the north side, living room in the northeast
Cost estimate according to the architect/planner: 550k
Personal budget limit for the house including fittings: 650k
If you have to give up something, which details/extras?
-can give up: fireplace
-can’t give up: kitchen island
Why does the design look like this? For example:
The big wish was views into the greenery from the various rooms.
The house was designed to blend into the plot. Since it is located at the edge of a HQ100 flood zone, the design includes an elevated terrace to create the impression of a house by the lake.
The basement was planned because of my wife’s part-time business and the architect’s statement that filling in the site wouldn’t be cost-effective, so a basement almost pays off again.
How can the design be made more efficient and welcoming? (staircase/pantry) Does the living room in the northeast make sense?
Topographic plan: green area with retention basin, biotope, and watercourse.
Modern, two-story villa in sketch style with terrace, steps, and person at entrance.
Basement floor plan: studio I & II, technical room, cellar, storage, utility room, stair corridor.
Upper floor plan: bedroom, 2 children’s rooms, corridor, bathroom, library, dressing room, roof terrace.
Ground floor plan: living, cooking/dining, room, shower/WC, stair corridor, terrace, carport, storage.
11ant6 Aug 2019 17:00
Cayman schrieb:
The front area is not as important to me as the kitchen and living space.
However, a subsidized accessory apartment must be genuinely suitable for independent household management (and usually also triggers parking space requirements).
6 Aug 2019 17:13
Cayman schrieb:
Keep the living area in the north? What about the pantry and stairs? Would swapping them make sense?
Well, swapping isn’t really possible because of the load-bearing walls. The structural engineering here is more critical than in a standard house.
You can’t just switch the stairs and kitchen around. The upper floor has to align accordingly.
I wanted to make a sketch, but without the plot/building envelope dimensions, it’s not possible. Sorry.
11ant6 Aug 2019 19:33
Cayman schrieb:
Keep the living area in the north? What about the pantry and the stairs? Would swapping them make sense?
Actually, a simple swap is not possible because of the load-bearing walls.
In #14 those are the same load-bearing walls, and in #17 I don’t see the swap as useful (since that would mean shortening the lower leg and lengthening the upper one).
6 Aug 2019 20:07
In #14, these are the same load-bearing walls, and in #17 I don’t see the exchange as reasonable (that would mean making the lower leg shorter and the upper one longer).
However, this doesn’t change what the original poster wants to achieve:
Cayman schrieb:
How can the design be made more efficient and user-friendly? (stairs/pantry)
In #14, only the children’s rooms get larger, while in #17 the living area completely turns away from the entering occupant, which was not preferred anyway.
Cayman
6 Aug 2019 21:31
Attached is a complete plan with dimensions... @ypg
Architectural plan: House floor plans for ground floor, upper floor, basement with garden and driveway.
Muc1985
6 Aug 2019 21:33
Definitely a great project!
