ᐅ Floor plan of an end-terrace house with a recessed top floor
Created on: 26 Jul 2017 21:04
Nordisch17
Development Plan / Restrictions: An end-of-terrace house must be built.
Plot Size: 10.66 m * 37.5 m (35 ft * 123 ft)
Slope: flat, facing west
Floor Area Ratio (FAR): 0.3
Site Coverage Ratio: 0.6
Building Window, Building Line, and Boundaries: 3 m (10 ft) to the southern neighboring plot (garage allowed)
Perimeter Development: yes, on the north side
Number of Parking Spaces: 1-2
Number of Floors: 2 full stories plus a set-back upper floor
Roof Type: shed roof / flat roof
Style: modern
Orientation: entrance east, garden west
Maximum Heights / Limits: minimum 6 m (20 ft), maximum 11 m (36 ft)
Owners’ Requirements
Style, Roof Type, Building Type
No basement, 2 full stories plus set-back upper floor, shed roof
Number of Occupants, Age: 2 adults in their mid-thirties, 2 toddlers
Space requirements on ground and upper floors
Office: family use or home office? Family use
Guests per year: 3-5
Open kitchen, kitchen island: both yes
Number of regular dining seats: 4
Fireplace: yes
Music / stereo wall: no
Balcony, roof terrace: roof terrace
Garage, carport: preferably a garage set back 5 m (16 ft) from the street (east) so a second car can be parked
Vegetable garden, greenhouse: no
Designer: planner from a construction company with own adjustments
What do you like most? Why? Kitchen facing the terrace
What do you dislike? Why? Living room is narrow
Personal budget limit for the house, including fittings: yet to be determined
Preferred heating technology: district heating
If you had to give up something, what?
Can give up: bathtub
Cannot give up: controlled ventilation system, lift-and-slide doors
Standard design from the planner with personal preferences incorporated: kitchen facing the terrace; washing machine/dryer in the upper floor bathroom; large sliding doors to the terrace.
Which requests were implemented by the architect?
A mix of many examples from various magazines and Pinterest
Nice open kitchen/dining area. The sofa corner is relatively narrow but almost identical to our current TV area in the rental apartment.
What is the main question about the floor plan in 130 characters?
General improvement suggestions? Position of garage/carport (with attached extra room)? How to use or divide the set-back upper floor?
Notes on the floor plan:
The kitchen still needs a window on the south wall and the exact dimensions of the lift-and-slide doors and kitchen island must still be discussed with the kitchen studio.
Access from the hall to the living room is still unclear regarding the type and width of sliding door.
Bathroom layout is not really planned yet; no bathtub needed, but a walk-in shower at floor level and washing machine/dryer required.
Due to the end-of-terrace condition and a maximum width of about 7.6 m (25 ft), we are naturally quite limited regarding changes, but we look forward to any suggestions from professionals here for optimization.
Best regards, Michi
Style: modern
Fireplace: yes
Best regards, Michi
Nordisch1729 Jul 2017 18:01The elongated layout wouldn’t change if we swapped the kitchen and the sofa area. We are considering raising the ceiling height slightly, which might help with that.
I think it can already be quite cozy as a TV/relaxation corner. Thanks, Willi, it’s nice to hear that it works well for you.
Nordisch17 schrieb:
We are considering raising the ceiling height a bit, which might help. Separate floor heights in a townhouse *scratches head* ? ? ?
Nordisch1729 Jul 2017 20:1011ant schrieb:
Different floor heights in a terraced house *scratches head* ? ? ?It's quite simple, the houses are each shifted by about 1 m (3 feet). I guess a few centimeters (inches) of that might be hidden.Nordisch17 schrieb:
Quite simple, the houses are each offset by about 1 m (3 feet). So, I guess a few centimeters (an inch) are hidden. If they are offset in height, yes.
Nordisch17 schrieb:
The elongated shape wouldn't change if we swapped the kitchen and the sofa corner. We're considering raising the ceiling height slightly, which might help with that. I think it can already be cozy as a TV/relaxation area—thanks Willi, nice to hear that it works well for you.However, the room appears even more narrow when the ceiling is raised.
I’m also a fan of kitchens, but I wouldn’t rule out that a kitchen with a parallel counter might not be worse.
If it stays as is, I would move the living room window, maybe add a narrow strip window (horizontal or vertical).
