Development plan/restrictions
Plot size: 549m² (5906 ft²)
Floor area ratio: 0.3
Building envelope, building line and boundary: 14 x 12m (46 x 39 ft)
Number of floors: 2 allowed with eaves height up to 4m (13 ft)
Roof style: Gable roof 38–45°
Maximum heights/limits: Eaves height max. 4m (13 ft); ridge height max. 11m (36 ft)
Additional requirements
Homeowner requirements
Style, roof shape, building type: Single-family house with gable roof, between modern and classic
Basement, floors: no basement
Number of occupants, age: currently 2, 29 years old, planned final 4
Office: family use or home office? Mainly family use as a guest room
Open kitchen, kitchen island: kitchen with sliding door, which will usually remain open except when cooking fish or hosting guests
Fireplace: chimney planned for masonry stove
Garage, carport: garage 9 x 4m (30 x 13 ft) planned, carport to follow
Additional wishes/features/daily routine: a small pool is planned
Who created the design:
- Planner from a construction company: yes
- Architect: yes
What do you particularly like? It is already quite close to our ideas but could be improved
What don’t you like? Staircase, layout of the upstairs bathroom
Preferred heating technology: undecided yet between air-to-water heat pump or gas (but gas needs a storage tank for the energy saving regulations, right?); geothermal energy not allowed
Please provide suggestions for improvements or optimization. I would especially like your opinions regarding the staircase. We would probably move the roof window from above the dressing room to above the stairs, any thoughts?
Edit: The house will have approximately 152m² (1635 ft²) of living space
- Architect: yes
I find the floor plan quite nice. In the hallway on the ground floor, I might consider creating a recess into the utility room to make space for a coat rack. The windows at the front on the ground floor seem too narrow, so the guest bathroom probably won’t get much natural light. Is the kitchen window only 1.13m (3 ft 8 in) high?
Sabine
Sabine
What are the views like?
Plot? Orientation?
I think it looks pretty good!
However, a cloakroom is definitely missing! If you don't plan a built-in wardrobe at the entrance, jackets and shoes will end up piling up under the stairs – which is not a pleasant sight from the kitchen and dining area.
Also, I assume the main terrace door will be in the kitchen (always close to the fridge). Because of that, there is some extra space in the living room that the office lacks. I would consider moving the wall a bit there.
Best regards in brief
Plot? Orientation?
While many prefer fixed windows or ones with a window sill, I like an open view of the garden and the opportunity to step outside everywhere.
In this respect, I would design this window in the living room as a patio door – eventually, you’ll regret not having direct access to the garden from this side.
Regards, Yvonne
Regards, Yvonne
Cico1 schrieb:
Do you still have any suggestions for improving the floor plan? They’re already there:
Curly schrieb:
In the ground floor hallway, I might consider creating an alcove in the utility room to make space for a coat rack. I also find the windows on the ground floor facing the front too narrow, Aotearoa schrieb:
If possible, I would also consider accessing the stairs from the living area.I would also put the coat niche there and widen all the narrower windows to 1.26 m (50 inches) in width. I like the idea of reversing the staircase direction.
Cico1 schrieb:
Yes, it’s a cozy fireplace that will be lit occasionally on weekends.
We haven’t chosen a model yet.I recommend the model “None.” That “occasionally” happens less often than you think. Then you turn the heating in the living room up by three degrees and watch the fire in HD TV. Your mind says “fake,” but your feelings “remember” sitting in front of the fireplace afterward. Psychology or whatever it’s called.
