ᐅ Gravel Borders Around the House and Paving Work: Pros and Cons
Created on: 4 May 2017 11:01
wiebkechristenseW
wiebkechristense4 May 2017 11:01Hello everyone!
The paving work is coming up.
Besides the big problem of finding an affordable paver, I would like to ask for your opinions on gravel strips.
In the residential area, it’s about evenly split whether a gravel strip is installed around the house during paving or not.
It doesn’t seem to matter whether the houses have brick veneer or are rendered.
Some even skip the drainage membrane.
Could I please hear your opinions and experiences?
Caspar20204 May 2017 11:31I understand that if you skip the gravel strip and, for example, place stones directly against the wall, it needs to be sealed additionally.
wiebkechristense4 May 2017 15:26ypg schrieb:
If you pave directly against the facade, there is a risk that rainwater will not drain properly and can damage the base of the wall due to frost and expansion.
There isn’t much more to say about it.
Best regardsI didn’t know that.
Even if there is an eave overhang and a slope?
Why do so many people still pave right up to the house then?
I thought the gravel strip was supposed to reduce the “splash-back” of rain droplets hitting the ground and thus prevent the facade from getting dirty. Isn’t that correct?
And if you pave right up to the house, wouldn’t the dimpled membrane still provide a gap and “frost protection”? [emoji848]
wiebkechristense schrieb:
So why do so many still pave right up to the house?Probably because they don’t know better?!
I thought the gravel strip is supposed to reduce the splashing of raindrops hitting the ground and thus prevent the facade from getting dirty. Isn’t that right???Also
wiebkechristense4 May 2017 20:25How wide should the strip be?
Is any type of gravel (regardless of color) particularly suitable for a gravel strip?
Or is any type rather unsuitable?
Do shape and size matter?
