ᐅ Carport Variation from the Building Permit / Planning Permission
Created on: 22 Apr 2017 17:15
Chriscross
Our architect included a carport with a storage room in our house plans right from the start. The building permit / planning permission was submitted and approved. The house is now built, but the carport manufacturer we initially chose no longer produces this type of carport. How much can I deviate from the approved plans without causing any issues? The original plan was for a carport measuring 6.5m x 9m (21 ft 4 in x 29 ft 6 in) with an integrated storage room of 3m x 6m (9 ft 10 in x 19 ft 8 in) and a flat roof. The carport is located 1m (3 ft 3 in) away from the neighbor’s property line.
Thank you for your help
Exempt from approval does not mean that everything is allowed. That is correct. But what exactly does this statement refer to?
Escroda schrieb:
That is correct. But what does this statement refer to?#8, not yours
Best regards in brief
#8 But that doesn’t really help the original poster. He wanted to know how much deviation from the building permit is allowed. The carport is apparently part of the building permit application. Therefore, he is only allowed to make changes that would also be permitted without approval if the carport were already built, such as changing the roof design. In my opinion, changing the size or location is not included, since the footprint of the carport exceeds the threshold for exempted modifications.
Payday schrieb:
you have a "hammerschlagsrecht" to paint your carport from the neighboring property. But then he would have to ask the neighbor. I do think the one meter (3 feet) makes sense. Unlike in NRW, it may not be less in Lower Saxony.
Bieber081524 Apr 2017 11:55Chriscross schrieb:
And it happily deteriorates on its own. Of course, constructive measures are taken to ensure that even two adjacent buildings sharing a common boundary do not deteriorate.Escroda schrieb:
Then he has to ask the neighbor. I definitely consider the one meter to be reasonable. Unlike in NRW, it is not allowed to be less in Lower Saxony. It simply doesn’t make sense to keep one meter clear at the boundary just to paint some beams every ten years. That is a lot of land that you still have to maintain unnecessarily.
To repeat for the third time: coordinate with your neighbors to agree on how to proceed. First, clarify whether you want to place one shared row of "stones" (e.g., boundary stones or blocks) together or if each of you wants to handle it separately (less practical, since each side loses 20cm (8 inches), resulting in a 2 × 15cm (6 inches) gap between the properties). If you place one row of "stones," these sit exactly on the boundary and will be concreted in on both sides. Additional advantages: you can share the costs.
If you want to close the carport side facing the neighbor with boards or similar, the neighbor won’t need a hedge or anything there. They might even create a flowerbed or something similar. To paint again in 10 years, you can agree that you will do the painting before they set up the flowerbed. For that, I wouldn’t give up 9 × 1 meter (9 × 3 feet). It’s like always driving a large van just to move furniture once every five years.
Payday schrieb:
It is simply nonsense to keep 1 meter clear at the boundary,We have the same, and I find it very practical that my car is parked under cover, yet I can open my doors generously.
Thoughtless standards can never be good and should always be reconsidered before implementation!
