ᐅ Window Replacement and Exterior Wall
Created on: 5 Jan 2021 21:44
MTSommer
MTSommer
5 Jan 2021 21:44
We have purchased a terraced house built in 1990 and unfortunately need to replace the old wooden windows.
Now we have the following questions: double-glazed or triple-glazed insulation? It is often said that the wall should insulate better than the window. According to the original building description, our exterior walls are made of 30cm (12 inches) thick thermal insulation bricks (see photo) and built with insulating mortar. But what is the exact U-value???
Or would you recommend insulating the facade before replacing the windows?
Can you recommend a window manufacturer with a good price-performance ratio? Currently, we are leaning toward plastic windows.
Thank you for your feedback.
Tonziegelplatte mit rechteckigen Belüftungsöffnungen, Holzbalken und Mörtel.
11ant6 Jan 2021 02:00
MTSommer schrieb:
We bought a terraced house built in 1990 and unfortunately need to replace the old wooden windows already.
Are you sure it's the windows themselves and not just the seals?
What exactly makes the windows in need of replacement?
What have the neighbors done regarding this (windows, façade)?
SchaeffnS
6 Jan 2021 10:54
We had a similar problem. We called in a window specialist. The windows were adjusted, some seals were replaced, a few new roller shutter straps, and a new handle on the patio door. That was all; the windows are still in good condition and no more drafts. Conclusion: have a professional take a look.
11ant6 Jan 2021 13:01
SchaeffnS schrieb:
Conclusion: Have a professional take a look.
In the sense of an expert, not a trader. Traders who sense sales opportunities don’t always remain impartial ;-)
MTSommer
6 Jan 2021 13:52
Hello everyone, thanks for your feedback. We already have new seals, but for some windows it no longer makes a difference. Unfortunately.
11ant6 Jan 2021 13:58
MTSommer schrieb:
We already have new seals – but on some windows, they don’t help anymore.
You’re not referring to those self-adhesive foam strips, are you? Those hardly help at all, especially if the sashes are misaligned. Why don’t you take some photos?
