ᐅ Why does my Billy bookshelf still wobble even after multiple wall fixings?
Created on: 30 Nov 2021 18:23
remojaHello everyone, I have a problem with my Billy bookshelf from IKEA, which still wobbles despite multiple wall fixings. I have already mounted the shelf three times using the supplied mounting hardware and appropriate wall plugs, but it remains unstable, especially when lightly used or loaded. The wall is a standard concrete wall, and I made sure to install the fixings securely into the wall, but the wobbling persists. Could it be that the anchors are insufficient due to the load or the height of the shelf? Or did I possibly make a mistake during installation? I look forward to helpful tips on how to make the shelf permanently stable. Thanks in advance!
Hello remoja,
First of all, thank you for your detailed description of the problem; it really helps in finding a solution.
The issue often lies in the type of wall plugs used. Especially with concrete walls, heavy-duty anchors should be used because standard plastic plugs can easily pull out when the shelf is loaded.
Another common mistake is attaching the shelf only at the upper holes of the drillings – for maximum stability, all designated anchor holes should always be used. Also, is the shelf board itself fixed to the wall or just the cabinet? Additional support can help, especially with larger units.
Summary of my tips:
1. Use heavy-duty anchors
2. Use all designated holes
3. Ensure the screws penetrate deeply enough into the wall
4. Consider using an angle bracket for additional stabilization
If you like, you can specify which plugs and screws you are using, so we can provide a more precise assessment.
remoja schrieb:
I have already installed the shelf three times using the supplied fasteners and corresponding wall plugs, but it remains unstable
Summary of my tips:
Matthewt481 Dec 2021 07:39Hello remoja,
I can confirm and add to the observations made by naujon. Often, the wobbling is simply due to the shelf not sitting completely flat against the wall. If the floor or wall has slight irregularities, it can happen that only one point is actually secured to the wall, while other areas have a small gap. This causes movement, especially if the shelf is taller.
Another helpful measure can be additional stabilization by attaching small plastic or felt pads to the back bottom, which can reduce wobbling. This prevents the shelf from shifting slightly all the time.
Also important: if your shelves are supporting heavy loads and the wall fixtures are close to the top edge, the shelf may sway at the lower part. Check that all screws are properly tightened; sometimes screws can loosen without it being immediately noticeable.
I hope this helps you move forward!
Hi,
I would simply check if the screws are securely tightened. Also, is the shelf standing on the floor or is it free-floating? If it stands on the floor and wobbles there, the floor might be uneven. You can place small wedges or non-slip pads underneath. This will hold the Billy securely in place.
Thanks in advance for the helpful feedback!
I used standard plastic anchors because they came as the default material. I hadn’t considered heavy-duty anchors before, but that seems sensible.
I will check carefully whether the entire back side is actually in contact and possibly try felt-based spacers.
The shelf stands on a relatively even parquet floor, but slight irregularities are certainly possible. Wedges or anti-slip pads also sound good, especially if the wall mounting only partially solves the problem.
I will replace the anchors and then review all the points mentioned again and report back, thanks to all of you!
naujon schrieb:
Often the issue lies in the type of anchors used. Especially with concrete walls, appropriate heavy-duty anchors should be used
Matthewt48 schrieb:
the shelf doesn’t sit completely flush against the wall
lofar schrieb:
Is the shelf resting on the floor or is it floating? If it’s on the floor and wobbles there, the floor might be uneven
Hello remoja,
I would like to build on the previous comments and add the following:
This is often the crucial point. Standard anchors are frequently not sufficient for tall shelves loaded with books or other heavy items. Heavy-duty anchors provide maximum load transfer into the wall thanks to their material and design.
Also important: make sure that the screws you use fit properly with the anchors. Screws that are too thin or too short reduce holding strength, even if the anchors are good.
Another tip: check whether the wall itself is truly solid. In older or porous walls, even heavy-duty anchors can fail. In these cases, it’s worth considering additional fixing with wall plugs or avoiding excessive load.
Finally, a reminder I often share: the correct sequence when fastening is important. First, insert all anchors, then screw in the screws lightly to check their position before tightening them fully – this prevents tension that can distort the shelf and cause it to wobble.
Good luck with the assembly!
remoja schrieb:
I used standard plastic anchors since that was the supplied basic material. I hadn’t considered heavy-duty anchors before, but that seems sensible.
