ᐅ Why does the shelf wobble even when mounted on the wall?
Created on: 23 Jun 2017 17:26
IXUSDAN
I recently installed a Billy bookshelf, following the instructions to mount it to the wall for stability. However, the shelf still feels noticeably wobbly, especially when slight pressure is applied to the shelves. I am curious why this might happen despite an apparently correct wall mounting. What factors could cause a Billy bookshelf to remain unstable even after being securely fixed to the wall? Are there specific installation methods, wall types, or material combinations that contribute to this instability? I look forward to detailed explanations and possible solutions.
TEKIN
24 Jun 2017 08:23
Additionally: A very important aspect is the load caused by weight and its distribution. If loads are unevenly distributed or the shelf is overloaded, this can cause wobbling even if it is assembled correctly.
Furthermore, the wooden panels themselves may be slightly warped, which affects the entire structure. For Billy shelves, it is also necessary to check whether the stabilizing bracket at the back is correctly and securely attached.
pikin
24 Jun 2017 11:46
TEKIN schrieb:
In addition, the wooden panels themselves can be slightly warped\
Exactly. Even a slight warp in individual boards can cause noticeable wobbling under light load. Often the only solution is to realign the entire shelf or adjust the individual boards.
KarTristan
24 Jun 2017 15:09
Another cause could be that while the wall bracket is securely fixed, the shelving unit has some play due to construction tolerances. For Billy shelves, the mounting bracket is relatively narrow, meaning small tolerances in wall installation or inaccurate drilling can result in slight wobbling, which is harmless.
Anyone wanting maximum stability can add extra brackets or battens to improve the firmness.
IXUSDAN
25 Jun 2017 09:37
Ianlau schrieb:
Special cavity anchors or metal expansion anchors should be used here
That explains a lot – my wall is actually drywall. I had only used the supplied plastic anchors, which might be the mistake.
KarTristan schrieb:
additional brackets or strips help to increase stability
I would like to try that too. Are there any recommendations on what type of brackets work best for the Billy shelf without affecting the appearance too much? Maybe flat, discreet brackets?
taotis53
25 Jun 2017 10:14
IXUSDAN schrieb:
Are there any recommendations on which type of brackets are best suited for the Billy shelf without affecting the appearance too much?
Flat steel brackets with a width of 30-40 mm (1.2-1.6 inches) and a thickness of about 2 mm (0.08 inches) are ideal because they are sturdy yet relatively unobtrusive. Corrosion protection is a bonus, such as galvanized or powder-coated finishes. Installation can be done on the inside of the shelf sides or from underneath, depending on your preference. It is important that the brackets are securely screwed to both the wall and the shelf.
For drywall (plasterboard) walls, cavity anchors with good load capacity are essential. Alternatively, if accessible, you can screw directly into a stud (wooden profile behind the drywall).
