ᐅ Why do some BILLY drawers stick?
Created on: 20 Aug 2020 13:24
Buix9
Buix9
20 Aug 2020 13:24
Some time ago, I bought a Billy shelving unit with drawers from IKEA. Now I have the problem that some drawers stick or are difficult to open and close, even though everything seems to be assembled correctly.
My question: Why do some BILLY drawers stick? Are there common causes that make the drawers hard to open and close or require a lot of force?
I would like to understand whether this is due to design issues, assembly errors, or material quality, and if there are simple ways to fix the problem permanently. Do individual parts shift during use, or are the drawers sensitive to moisture?
I’m looking forward to your experiences and advice!
jelite
20 Aug 2020 13:37
Hello Buix9,
“Why do some BILLY drawers stick?” is actually a common question because the design is quite simple, but small details often cause issues.
Typical causes include:
1. Incorrect installation: The drawer slides must be perfectly straight and exactly parallel to each other. Even slight deviations can make the drawer stick.
2. Material swelling: With wood or wood-based materials, moisture can cause slight expansion, which tightens the drawers.
3. Wear or deformation: Over time, rails can warp slightly.
4. Foreign objects or dust in the drawer slide.
My advice: First, check if the drawer slide is properly aligned. If you notice sticking at a certain point when sliding, gently sanding the rails can help. Applying silicone oil to the slides also reduces friction.
Hope this helps you for now!
DAMALO
20 Aug 2020 14:02
I completely understand how frustrating it is when drawers suddenly start sticking. 🙂 I had a similar experience a few years ago when I assembled my Billy shelf. Everything seemed to be perfect, but the drawers just wouldn’t slide smoothly.
In my case, it turned out that I hadn’t paid close enough attention to the subtle differences when installing the drawer slides.
Do you have detachable drawer slides or regular screw-on slides? It might help to remove the drawers completely, check the system, and then carefully realign everything.
Hang in there, it usually can be fixed! 🙂
jordanvin
20 Aug 2020 14:29
Hey Buix9!
It’s great that you’re taking such a close look at the Billy shelf. 🙂
I had the same issue once, and for me, it was a combination of assembly and humidity. The drawers would stick especially in summer when it was very humid outside.
My tip: try removing the drawers slightly and wipe the sliding rails with a dry cloth. After that, I lightly rubbed them with candle wax. Afterward, the drawers ran much more smoothly!
Don’t get discouraged, it will work out! 🙂
Danabla
20 Aug 2020 15:11
Regarding the question "Why do some BILLY drawers stick?" I can add that the drawers in the BILLY series run on plastic runners designed for ease of use but are not high-performance slides.
Objectively, sticking usually occurs due to the following factors:
- Inaccurate alignment of the runners during installation
- Insufficient adjustment of the side panels
- Temperature and humidity changes causing slight expansion of the engineered wood materials
- Dirt or loose parts inside the runners
To resolve this, it is recommended to:
- Check the alignment using a spirit level
- Remove any dirt from the runner
- If necessary, readjust by slightly loosening and better securing the screws
Material technology is also relevant here: particleboard absorbs moisture more than solid wood, which affects the precision of the fit.
JORGERON
20 Aug 2020 15:43
Most of the time, jamming is caused by misaligned guides. Check the screws and reposition them if necessary. Keep the sliding rails clean. That’s all it takes.
