ᐅ Why do some Billy bookcase doors no longer fit the shelves perfectly?
Created on: 27 Aug 2020 10:07
lasau
lasau
27 Aug 2020 10:07
I have recently noticed that some Billy doors no longer fit perfectly on the shelving unit and either close with difficulty or get stuck on the sides. This does not seem to be just a matter of installation, as I found no obvious mistakes during assembly. My question is therefore: why do some Billy doors no longer fit perfectly on the shelving unit, even though everything appears to have been installed correctly? Could material changes, production tolerances, or environmental factors play a role? I would like to understand if there are typical causes or known issues and how to best fix them without damaging the doors or the shelving unit.
maureo
27 Aug 2020 10:12
Often, the hinge alignment is not quite correct. This can usually be quickly fixed by readjusting. Warped doors caused by moisture can also be a reason.
Katau
27 Aug 2020 11:37
Hello, I completely understand the question. There are actually a few common reasons why doors on Billy bookcases might not fit perfectly anymore:
1. Manufacturing tolerances: Although IKEA strives for precision, slight deviations in door dimensions or cabinet structure are normal.
2. Material swelling: The doors are made of wood-based materials that react to moisture and can undergo slight warping.
3. Hinges and installation: Adjusting the hinges can be tricky, and it is sometimes unclear how to set them optimally.
4. Wear and use: Doors are subject to minor mechanical stresses during use, which can cause changes over time.
The best approach is to systematically check all these factors and adjust them slightly if necessary. Patience pays off.
besau
27 Aug 2020 11:39
Sometimes it is enough to slightly loosen the screws on the hinges, realign the door, and then tighten them again. Also, check if the shelf itself is level.
naujon
27 Aug 2020 15:29
I would like to explain the causes in more detail because the problem is not always obvious at first glance:
First: The Billy doors have an MDF core with a foil coating. MDF reacts to changes in humidity by swelling or shrinking. This can alter the dimensions, especially if the doors are placed frequently in more humid or drier rooms.
Second: The hinges are designed to offer various adjustment options, typically in three directions. Unfortunately, this adjustment is often used inadequately or misunderstood. It is important to initially loosely attach the doors, align them, and then fine-tune the screws in small steps.
Third: The installation itself. Especially if the Billy shelves are not fully mounted flat against the wall, the shelf can easily distort or tilt, which in turn affects the door alignment.
In conclusion, I recommend proceeding step by step:
1. Check if the shelf is truly level and securely fixed.
2. Inspect the doors for deformation.
3. Loosen the hinge screws and reattach the doors.
4. Slowly adjust the screws while checking how the doors open and close.
Patience and gentle adjustments, rather than forceful ones, are essential.
FEKAU
27 Aug 2020 16:47
From a technical perspective, there are usually two main reasons for ill-fitting doors on Billy bookcases:
1. Dimensional tolerances in production: IKEA products are mass-produced, which means certain manufacturing tolerances apply and combine with the conditions during assembly.
2. Material properties: MDF and similar engineered wood products expand with humidity and contract when dry. These fluctuations cause slight dimensional changes that are often barely visible to the naked eye but can lead to fitting issues.
The problem can often be resolved by adjusting the hinges. If this is not sufficient, it is recommended to acclimate the doors to the room climate before use.
