ᐅ Why do some BILLY doors no longer fit after relocation?
Created on: 15 Dec 2021 08:17
Pegikin
Pegikin
15 Dec 2021 08:17
Hello everyone, I recently moved and tried to install my Ikea Billy cabinet doors at the new location. However, I noticed that some doors don’t fit properly anymore – they either stick or don’t close flush. My question is: Why do some BILLY doors no longer fit perfectly after a move, even though the doors themselves seem unchanged and the cabinets still have the same dimensions? I’ve been careful about maintaining measurements during disassembly and reassembly, but I’m unsure if changes in the frame dimensions, uneven floors, or other factors might cause this issue. Has anyone experienced this problem or have tips on what to watch out for specifically when moving and reinstalling these cabinets?
Landontau
15 Dec 2021 08:45
Hello Pegikin,
First of all, your question is very well formulated and covers several important aspects. I have often experienced that BILLY doors no longer fit perfectly after moving, and I am happy to explain the most common causes and solutions.
1. Differences in the floor: The floor at the old location may have been completely level, while the new one is slightly sloped or uneven. This can cause tension, preventing the doors from closing properly.
2. Wall dimensions and shelving tolerances: Even small deviations in the partition wall at the new site—for example, the angle may no longer be exactly 90 degrees, or the back panel might be slightly warped.
3. Installation inaccuracies: Screws can become slightly looser or tighter during disassembly, which affects door adjustment.
4. Moisture and material changes: Wood-based materials expand or contract slightly depending on humidity.
My tip: Check the floor and shelf frame with a spirit level, readjust the hinges (e.g., using the adjustment screwdriver), and make sure no deformations have occurred.
In summary: The issue usually comes down to minor fitting inaccuracies and the lack of precise alignment at the new location. Hope this helps!
SAWYERR
15 Dec 2021 09:03
Uneven floors and irregular wall angles are often the cause. When installing, make sure the doors are properly aligned and the hinges are correctly adjusted.
BENBI
15 Dec 2021 10:14
Landontau schrieb:
Differences in the Substrate:
This is actually the crucial point I would like to elaborate on: BILLY shelves are designed so that the doors work well within an exactly square frame. If the floor or wall shifts slightly during the move, for example due to uneven floors with differences of 3–5 mm (0.1–0.2 inches), it can cause the door to jam.
At this point, you absolutely need to measure precisely with a level to ensure that the entire frame is square and flush. Often, it is forgotten to adjust the shelf feet accordingly. Since BILLY shelves have adjustable feet, you should first make this adjustment to create compensation.
Also important: The BILLY doors have hinges that are adjustable in multiple planes – vertically, horizontally, and in depth. Especially during reassembly, screws are sometimes tightened too much or not set optimally, which limits functionality.
Furthermore, I recommend checking the back panel for damage or warping – slight bulges or bends can distort the frame.
Another question for you: Did you fully dismantle the doors before the move or leave them attached to the shelves? Sometimes the combination of built-up shelves plus transport distortions has an effect.
Keep in mind: This topic requires careful adjustment, otherwise sticking and fitting problems occur even though the components are identical.
BOLUKEO
15 Dec 2021 10:46
This often happens when the new substrate is not perfectly level. Also check whether you have tightened the screws of the hinges properly during installation; sometimes a fine adjustment helps.
joroti
15 Dec 2021 11:20
Check the door hinges, as they have adjustment options and may have shifted after moving. Small angle deviations in the wall often cause issues.
