I have a problem with my Billy shelves from Ikea: some of the doors seem misaligned. They no longer close flush, are crooked, or rub against the frame. I have already tried adjusting the hinges, but that didn’t fully solve the issue.
My question is: what measures or tricks really work effectively to properly realign misadjusted doors on Billy shelves? Are there any settings that are less well known, or experience with special techniques? I would prefer to avoid removing the entire door or completely readjusting the shelves if possible.
Thanks in advance for your tips and advice!
Hello Tubigau,
it’s great that you asked the question in such detail. That makes it easier to provide help.
If your doors are misaligned or don’t close properly, as already mentioned, adjusting the hinges is usually the first and most important step. Some also recommend securing the shelves at the base to prevent tipping – an uneven floor surface can cause the doors not to close correctly.
If the doors are rubbing or show surface damage such as peeling or swelling, a warped or swollen door panel might be the cause. In such cases, the only solutions are to replace the door or refinish the surface accordingly.
Sometimes lubricating the hinges can help if there is squeaking or sticking.
How stable is the entire shelving unit for you? Is it standing level?
Raymond schrieb:
Often enough: Secure shelves to the floor to prevent tipping.That’s true. A shelf that is not level is usually the number one cause of crooked doors.
Thank you for the helpful answers so far.
To add some details: The shelves are flush. I also checked whether the shelves are properly positioned – everything is fine. Some of the doors hang slightly crooked, not significantly, and when they close, there is unfortunately a small gap that wasn’t there before. I think it’s a combination of slight hinge adjustment and maybe minimal warping of the cabinet frame.
@PLOMA
Thanks, I will systematically check and adjust all three adjustment screws. How precise do you need to be? Is it possible to adjust so minimally that the door gap is almost visually invisible, or will there always be small inconsistencies?
@GALEO4
Your idea with the magnetic catches sounds interesting – have you already tried that on Billy? I would be curious to know if it actually works better in the long term.
@PLOMA
@GALEO4
Tubigau schrieb:
How precise do you have to be? Is it possible to adjust the door gap so that it is visually almost invisible, or are small unevennesses always present?Yes, it can be very precise, provided the shelf unit itself is completely straight and the doors are produced accurately. The adjustment screws on Billy hinges allow millimeter-accurate settings. I recommend the following procedure:
1. Check the floor and align the shelf unit.
2. Adjust the door completely in the open position (first sideways, then height, then depth).
3. Check the door gaps using a straight ruler or a thin strip.
4. Perform fine adjustments again until no visible gaps remain.
This requires a delicate touch but works very well with the right tools. Minor unevennesses are often due to production edges or slight material tolerances but are hardly noticeable in normal use.
Tubigau schrieb:
Your idea with the magnetic catches sounds interesting – have you already tried this with Billy?I know some DIYers who use this option with magnets, especially for significantly warped doors. The magnetic solution often replaces the mechanical hinge function or supplements it as holding force, so that the doors do not shift as easily anymore.
Tubigau schrieb:
The doors are slightly misaligned, not severely, and when they close, there is unfortunately a small gap that wasn’t there before.In this case, I would also recommend fully loosening the hinges before making any adjustments and then performing a complete realignment. Especially if the doors were properly aligned before, it’s possible that over time, due to furniture movement or weight, the screws loosen slightly, affecting the alignment.
If the gap is barely visible, it’s worth checking the adjustment of the upper and lower hinges separately, as small height differences there often cause disproportionately large gaps.
Also: Slight sanding where the hinge engages with the frame can help if the door panel sticks due to slight swelling.
