ᐅ Why do softwood components like pine warp so easily?
Created on: 30 Apr 2018 08:17
U
ugurnu
U
ugurnu
30 Apr 2018 08:17
I am currently working on a piece of furniture and have once again noticed that particularly wood parts from the IKEA Malm range tend to warp quite easily. I am interested in understanding why this happens.
I am aware that wood is generally hygroscopic and reacts to moisture, but the issue seems especially pronounced with the Malm components. Could this be due to the type of material, for example particleboard or MDF manufacturing, the surface treatment, or perhaps the production processes?
Are there specific technical reasons why Malm wood parts are so prone to warping, such as internal stresses in the material, inadequate drying, or possibly insufficiently processed glue?
I would appreciate any explanations or insights that could help me better understand this phenomenon. 🙂
Klakar
30 Apr 2018 08:45
Wood components made from particleboard or MDF are generally more prone to warping because they absorb moisture, causing the fibers to swell. Malm typically uses these materials, which is why the parts tend to warp easily.
dota57
30 Apr 2018 09:12
It is important to know that Malm furniture is primarily made from engineered wood materials composed of bonded wood fibers or chips. These materials react to moisture more strongly than solid wood because they have a larger surface area that can absorb moisture. Additionally, uneven coating or insufficient sealing can cause moisture to penetrate unevenly, which in turn creates internal stresses and warping.
kaju67
30 Apr 2018 09:37
There’s some truth to that! Malm furniture is affordable, but it does not handle moisture and temperature fluctuations well. The wood can essentially “sweat,” which then leads to warping—almost like it’s in a bad mood 😉
Also, it’s not solid wood craftsmanship; the pieces are glued and coated. The different layers can expand at different rates, which creates stress on the whole structure.
My advice: Use Malm only in dry, stable indoor environments; otherwise, you’ll often have to deal with warped boards.
klabe
30 Apr 2018 10:07
Let me summarize and explain a bit:
1. Material type: Malm mainly uses particleboard or MDF, which are made by pressing wood particles and glue together. These materials are more sensitive to moisture than solid wood.
2. Hygroscopicity: Wood-based materials absorb moisture, which changes their shape and size – this swelling affects flatness and dimensional stability.
3. Layer structure: Glued layers of wood fibers can react differently to moisture, leading to internal stresses and ultimately warping.
4. Surface treatment: IKEA furniture often has only a thin melamine or foil coating, which is not completely sealed, especially at edges and cut surfaces, allowing moisture to penetrate.
5. Production: Mass-produced, low-cost furniture is often made from panels that were not optimally dried or still contain residual moisture, which reduces durability.
Conclusion: Warping is technically understandable with these materials when exposed to moisture and fluctuating temperatures. For better durability, it is recommended to use well-dried materials, careful sealing, and stable indoor climate conditions.
KarTristan
30 Apr 2018 11:21
The dimensions of the parts are also important. Larger surfaces made of particleboard or MDF panels tend to warp more quickly due to the material properties and internal stresses during drying and reacting to humidity.
Furthermore, insufficiently stabilized edges and glue joints can cause the panels to bend or warp under unfavorable conditions.
I recommend reinforcing larger components with stabilizers whenever possible or using alternative wood-based materials with lower moisture absorption if warping is a concern.
