magdalena5 Jul 2020 10:19Hello everyone,
I have a question that has been on my mind for some time, and it concerns the Billy shelves from IKEA. I have noticed that these shelves seem to warp after extended use, meaning they no longer remain straight and begin to bend or warp. I’m not just referring to a visual change caused by weight, but an actual deformation of the wood or particleboard.
My suspicion is that the material might be reacting to moisture or load, but I’m uncertain whether that is the main cause or if it could also be related to manufacturing, storage, or installation.
I would be interested to know the exact reasons behind the warping of the Billy shelves, whether it can be prevented, and if it depends on the quality of the material. Does anyone have knowledge of the technical background or practical experience that could clarify this?
I look forward to your insights!
I find this topic really interesting and can understand your observation, magdalena. It has bothered me quite a bit myself when I used a Billy-style shelf.
From my own experience, I would say that warping is often related to how the furniture is used. As you already suspect, moisture plays a major role. If the shelves are made of particle board or MDF, they tend to absorb moisture – which causes them to swell, and when drying out, the panels warp.
Additionally, it is often the case that the load from heavy items without proper reinforcement becomes too much over time. The shelves are not always designed to carry very heavy loads.
What is also sometimes overlooked is storage before assembly: if the parts were not stored flat and dry, stresses can develop even before use.
Therefore, I would advise you to be mindful of moisture and to support the shelves with additional braces if you place heavy objects on them. That might help in your case as well 🙂
moses schrieb:
If the shelves are made of particleboard or MDF, they basically absorb moistureI see it a bit differently. I don’t think moisture alone is the main issue. I mean, IKEA has sold millions of Billy shelves—if there were massive quality problems like that, they would have been well-known and heavily complained about long ago, right?
I believe it mainly comes down to the material quality and design. Billy is a budget product: the melamine coating is thin, the chipboard is inexpensive, and to save costs, supports and reinforcements are minimal. So when you put “normal” loads on it or have the shelf in a crowded living room, it can start to sag.
In a way, warping is an unavoidable consequence of cheap furniture construction. But hey, if you’re smart, you reinforce it afterward or don’t place the shelf in a damp basement.
Just my opinion, but I think people shouldn’t be too harsh on budget furniture. If you want something more stable, you have to invest more. 🙂
I would like to approach this from a more technical perspective:
Billy shelves are usually made from particleboard with a melamine coating. These boards are multilayered, composed of compressed wood particles and a resin binder. The melamine coating provides surface protection against scratches and moisture, but it is not completely waterproof.
It is important to understand that wood-based materials like particleboard are hygroscopic. This means they absorb or release water depending on the surrounding air humidity. As a result, the board can swell or shrink. Especially with low-cost particleboard, dimensional stability is often limited because they generally have fewer and thinner core layers.
For example, if a shelf is heavily loaded on the underside, it will bend. This mechanical load combined with fluctuations in air humidity can lead to permanent deformation over time.
In addition, temperature and humidity changes create internal stresses within the material, which may result in lasting warping.
My recommendations for long-term stability are therefore:
1. Place the shelf in as dry a location as possible (relative humidity 40-60%)
2. Do not overload the shelves; follow the manufacturer’s specified load limits
3. For heavy loads, install an additional central support (e.g., a vertical brace) to prevent bending
If the shelf is already warped, replacement is sometimes the only solution.
Finally, I am curious, magdalena, how much weight your shelves are carrying and whether they have been exposed to moisture? That would help with the diagnosis.
magdalena6 Jul 2020 12:47TEBILO schrieb:
If the shelf has already warped, sometimes replacement is the only solution.Thank you for the detailed technical explanation – it really helps me understand the situation better.
Regarding your question: My Billy shelves are mostly loaded with regular books and decorative items, so they’re not under excessive weight. The shelves are in my study, not directly in a damp room, but there are still temperature and humidity fluctuations, especially in winter due to the heating.
I haven’t installed a center support beam so far and didn’t really think it was necessary for the Billy shelves. I’m now guessing this might be the main issue – with prolonged load and changing climate conditions, the shelves warp simply because they lack the needed stability.
LIELCHEN schrieb:
Billy is a low-budget product after all I agree to some extent, but I would see it more as a compromise for the price rather than poor quality.
I’m also interested if you have other recommendations on how to extend the lifespan of these shelves. For example, special care, suitable shelf liners, or simply adding a center support? Thanks in advance for any tips! 🙂
