I am planning to buy a Billy bookshelf from IKEA and am currently looking into which Billy models are the most durable. I have noticed that there are different versions – from thinner standard shelves to slightly thicker ones. I am particularly interested in how the various models hold up over time with everyday use, especially when the shelf is heavily loaded, for example with many books or even heavier items.
Are there people in this forum who have experience with different Billy versions and can share which models are the most stable in terms of quality? I am interested both in actual usage reports and assessments regarding the materials, workmanship, and possible weak points.
Thanks in advance for your help!
Hello Rudybau,
I completely understand your question – I had my doubts about durability last year too. I chose the classic Billy with a depth of 28 mm (1 inch) and mainly use it for books. After about a year of use, I can say it is surprisingly sturdy, even though I packed it quite full.
However, the issues for me were mostly with the shelves, which started to bend slightly over time. I then added extra supports, which really helped.
I think the models with thicker panels do make a difference. Has anyone tried the other versions?
Hey everyone! 😄
I can only agree with Henry—thicker shelves are the key to durability with Billy, especially if you’re loading it up with a lot of books. Back then, the "Billy XL" model really convinced me—it looks quite similar to the standard version but has stronger shelves and feels higher quality.
Honestly, I was worried about the thin boards too, especially since I wanted to store heavy items. But with Billy XL, I haven’t experienced any sagging or wobbling so far.
So, if you want a sturdy Billy and don’t want to waste a single centimeter (inch) of space, check out the XL version. It costs a bit more, but in my opinion, it’s totally worth it! 😉
A brief technical overview: The durability of the different Billy models largely depends on the thickness of the panels and the type of wood used (particleboard vs. MDF). The classic Billy shelves use particleboard with a melamine coating, which is cost-effective but more susceptible to moisture and sagging under heavy loads.
The XL versions often use thicker panels with an additional crossbar that distributes the load to higher levels. This helps prevent sagging.
The fastening methods (profile moldings, dowels) can also affect stability. It is recommended to secure the shelves to the wall, especially for extended use.
For maximum stability, you can also reinforce the shelves with metal brackets or inquire about retrofit parts at IKEA.
The following facts should be considered:
- Standard Billy shelves are made from 16 mm or 18 mm (0.6 inch or 0.7 inch) particle boards, while the XL models have thicknesses of 25 to 28 mm (1.0 to 1.1 inches).
- The XL models can support loads of up to approximately 40 kg (88 lbs) per shelf due to the increased material thickness, whereas standard shelves are usually rated for up to 20 kg (44 lbs).
- The most common damage results from overloading and missing wall mounting.
- For long-term use, it is recommended to use wall fastenings and to insert metal reinforcements.
Therefore, those who value durability should either choose the XL model or upgrade the standard version with technical enhancements.
Hello Rudybau,
your concern is quite valid, as the lifespan of a shelf largely depends on the material and its use. I have had good experience with the tall Billy shelf in the XL version, where the shelves do not bend even when loaded with heavy books. It is also important to regularly check screws and fastenings, as they can loosen over time.
For heavy loads, I additionally recommend never filling the shelf to its maximum weight capacity, as this greatly improves durability.
Are there specific models you are particularly interested in?
