ᐅ Who else uses the KALLAX in the basement as a tool shelf?
Created on: 17 Mar 2016 09:23
V
Vedran
V
Vedran
17 Mar 2016 09:23
I’m currently working on optimizing my basement and considering using my IKEA KALLAX shelf as a tool organizer. My question to everyone here: Who else uses the KALLAX in their basement for storing tools? I’m especially interested in how you organize the compartments, whether the shelf is sturdy enough for heavier equipment, and if you use any specific inserts or boxes to keep things tidy.
Additionally, I would like to know how you protect the shelf from moisture or dust in the basement so that the tools stay in good condition for a long time. So far, I’ve only had an open board with hooks, but that often gets too messy and cluttered.
I’m looking forward to your experiences and tips, especially clever solutions for small tools and accessories that tend to get lost. Thanks in advance!
RUBEN54
17 Mar 2016 12:41
Hello Vedran,
I actually use my KALLAX shelving unit in the basement as a tool rack and can share some tips on how it works and what you should keep in mind.
First of all: The standard KALLAX shelves are quite sturdy, even though they are not specifically designed to hold heavy tools. It is important to place the shelving on an even surface and avoid overloading the shelves – for example, store heavy items like drills or cordless screwdrivers on the lower shelves, and lighter items higher up.
I also use plastic boxes and baskets that fit well into the compartments to keep small parts like screws, wall plugs, or bits organized. This helps a lot, especially if one of the boxes tips over, as it prevents everything from scattering inside the shelf.
Regarding moisture, you can simply place a waterproof mat on the floor and wipe down the shelf regularly. A small silica gel pack or dehumidifier nearby also helps a lot to avoid rusting tools.
In summary:
1. KALLAX is suitable but should be loaded carefully
2. Plastic boxes or organizers are useful
3. Don’t neglect moisture protection
Hope this helps you a bit!
O
onfebe
17 Mar 2016 15:07
RUBEN54 schrieb:
A small silica gel pack or dehumidifier nearby also helps a lot to prevent rusty tools.
I can only agree with that. I used the KALLAX in my basement as a tool shelf as well, but only after I noticed that my metal tools were starting to rust did I switch to a dehumidifier.
What also helped me a lot back then was regularly checking the organization. Especially with tools, I often have the problem that things get placed somewhere without a fixed spot, and chaos quickly develops.
For me, boxes with labels, whether homemade or store-bought, work really well. Adding a few hooks on the side for frequently used screwdrivers or a hammer makes the shelf perfectly organized.
I think it’s great that you put so much thought into it – a well-planned system really brings peace while working and is good for your well-being 🙂
TEBILO
18 Mar 2016 10:36
Vedran schrieb:
I’m particularly interested in how you organize the compartments and whether the shelf is sturdy enough for heavier tools
To add some technical details: The KALLAX is basically a modular shelving system made of medium-density fiberboard (MDF) core panels, reinforced with sturdy edge profiles. For use in a basement as a tool shelf, it’s important to consider the following:
1. Maximum load per compartment: IKEA states about 13 kg (29 lbs) per compartment, but in practice, this can vary under basement conditions due to moisture. It’s unavoidable that high humidity causes the wood to swell more easily.
2. Securing the shelf: Be sure to fix the shelf to the wall to prevent tipping—especially when handling heavy tools.
3. Organization: I recommend using sturdy plastic boxes with handles that can be easily pulled out. Metal or wooden boxes can damage the MDF if they are damp.
4. Dust and moisture protection: In addition to a dehumidifier bag, I suggest lining the back panel of the shelf with water-resistant material (e.g., laminate foil).
5. Custom solution: For very heavy tools, you can build a solid wooden base under the KALLAX to carry the load and use the shelf primarily for organizing smaller tools.
onfebe schrieb:
A well-thought-out system really brings peace to your work and is good for your mindset
I fully agree; having an organized environment is invaluable when working in the basement.
One more question for you, Vedran: How large is your KALLAX shelf, and what types of tools are you mainly planning to store? That way, more targeted advice can be provided.
