ᐅ What tools do I need for the Ikea Hemnes assembly?
Created on: 26 Aug 2022 09:13
Len10
Hello everyone, I am planning to remodel my Ikea Hemnes wardrobe soon, specifically to adjust the doors and the interior layout. Before I get started, I want to make sure I have the right tools on hand. My question is: What tools are ideally needed to professionally remodel an Ikea Hemnes wardrobe? I am interested in the basic toolset as well as any helpful specialized tools that could make the remodeling easier. Tips on tool brands or experiences with certain devices are also very welcome!
JAMESONB41
26 Aug 2022 12:50
Replacing a soft-close hinge: cordless drill with a Phillips bit, possibly a screwdriver for fine adjustments. Attaching the back panel: cordless drill, screws (3-4 mm). Cutting: handsaw or jigsaw, sandpaper for finishing.
Len10
26 Aug 2022 14:06
bauku schrieb:
For cutting, I recommend a fine-tooth handsaw, as it provides clean cut edges.
That sounds reasonable. I have read that some people also use a table saw, but I don’t have access to one. Would a handsaw combined with sandpaper be sufficient to achieve a visually appealing finish, including on the edges? I want to treat the wood not only functionally but also keep it looking good.
gekira
26 Aug 2022 14:45
A fine-toothed hand saw combined with fine sandpaper (grit 180-220) is sufficient for clean and visually appealing cuts and finishing. For edges, an edge protector or furniture molding can also be used to cover and protect the cut edge. While a table saw provides cleaner cuts, it is not strictly necessary for private renovations.
PECLARISSA
26 Aug 2022 15:10
A small tip: When cutting with a handsaw, draw a guide line with a pencil and cut slowly; this helps to make a straight cut 😊 For the edges, I used fine edge strips, which give the piece of furniture a nice finishing touch.
Hector
27 Aug 2022 08:17
Len10 schrieb:
Are specific screws or tools useful here?
Which screws are most suitable largely depends on the material of the back panel. Is it hardboard or particleboard? For thinner hardboard panels, pre-drilling with a countersink drill bit is recommended to prevent the wood from splitting. Alternatively, so-called furniture back panel nails can be used, which can be inserted and removed more quickly if you plan to take off the back panel frequently.
NIKA61
27 Aug 2022 08:53
For drilling additional holes in the back panel: a cordless drill with a wood drill bit and countersink bit is very useful. I often work with panel pins, but if you want stability, screws with pre-drilling are better.
