ᐅ How can you prevent the back panel of Billy bookshelves from breaking?
Created on: 1 Jul 2016 08:17
Emric
I have several Billy shelves from IKEA, and on one of them, the back panel has broken. Now I am wondering how to specifically prevent the back panel on these Billy shelves from sagging or even breaking over time. I am especially interested in the mechanical and structural weak points that cause such damage. Does anyone have experience with whether it makes sense to attach the back panel differently or maybe reinforce it? Or is the problem often related to the frame of the shelf or the type of back panel itself?
Looking forward to your tips and experiences!
pauPierce
1 Jul 2016 11:04
Emric schrieb:
Good question, I mainly use the shelf to store books...
Thanks for the information, that makes the situation easier to understand. Shelves holding a lot of books often experience point loads from heavy books, which is why the thin back panel tends to bend more easily.
Regarding the choice of battens: The ideal size is about 15–20 mm (0.6–0.8 inches) wide and 15 mm (0.6 inches) thick, preferably made of spruce or pine wood, as it is lightweight yet sturdy. Before screwing them on, the edges of the battens should be slightly rounded or sanded to prevent the shelf wood from splitting.
Placement is best done vertically on both sides and additionally in the center or slightly offset on the lower shelf panel, as this area bears the most load.
Use a generous number of screws, but avoid tightening the back panel too firmly so it can still settle slightly.
P.S.: Adding a second shelf with dowels might also help reduce the load on the back panel.
lis64
1 Jul 2016 11:30
A small addition: Place rubber pads under the shelf if it stands on an uneven floor. This helps prevent stress that could further weaken the back panel.
Santiagobu
1 Jul 2016 12:03
Hello Emric,
I would also like to emphasize that proper attachment of the back panel during assembly is crucial. The back panel should be tight but not nailed or screwed in too tightly, as this can create stress that may lead to cracks over time. For my Billy bookshelf, I always cut a back panel from sturdy MDF board and secured it with screws driven in from the inside. I used small wood shims as spacers to prevent any tension from developing.
When it comes to the size of the back panel, it can help to cut the board to the exact millimeter—neither too small nor too large, to avoid pressure points.
If your back panel is already slightly cracking, I would suggest replacing it and definitely substituting the nails with screws for the new panel.
Good luck!
relupa
2 Jul 2016 07:45
I can understand how frustrating this problem can be, especially when you use the shelf daily and suddenly notice damage.
LENNAU schrieb:
Replacing the thin nails with small screws to prevent splitting
This exact small change made a big difference for me. Additionally, I always mounted the back panel with a slight gap so that air can circulate. This prevents moisture buildup, which is often the cause of warping.
If the shelf feels unstable, you can also try attaching the back panel to the shelf corners from the inside using suitable brackets. This stabilizes it further and prevents the back panel from bending outward.
I hope your problem can be resolved easily and permanently!
RATAR
2 Jul 2016 08:12
I have also been concerned about this issue for a long time because I often use the shelf for school books, and the back panel in my case got damaged after only a few years.
I have found that it is better to protect the back panel from the start by assembling the shelf not upright but with the back side facing down on the floor. This way, the back panel is installed without stress and warping during assembly is avoided.
As already mentioned many times, screws are definitely a better choice compared to nails. Another tip from me: when screwing, always pre-drill slowly to prevent the wood from splitting.
Another problem is that the thin back panel material has very few fixing points. I increase the number of screws by adding extra joints at the edges, which is often enough to prevent a break.
giabau
3 Jul 2016 09:41
Emric schrieb:
Can you also say how thick the battens should ideally be and what type of wood?
Sure! For the battens, I recommend a width of 15-20 mm (0.6-0.8 inches), thickness about 15 mm (0.6 inches), ideally a soft coniferous wood like spruce or pine. These woods are easy to work with and relatively lightweight. When drilling, make sure to properly prepare the battens by sanding the edges—this prevents cracking when screwing them in tightly.
For installation:
- Attach one batten vertically along the inner edges of the back panel
- At least one batten horizontally in the lower third on the inside
The combination of vertical and horizontal reinforcements significantly improves stability and reduces stress on the thin back panel. Don’t screw the battens in too tightly, so the wood can “breathe” and absorb movement.
I often use this method for my Billy shelves and haven’t had any issues so far. If you want, I can send you a simple sketch via message.
