ᐅ KALLAX Back Panel Splinters When Nailing – How to Prevent It?
Created on: 19 Jan 2015 08:42
barpanayotB
barpanayot19 Jan 2015 08:42Hello everyone,
I am currently facing the problem that the back panel of my IKEA KALLAX shelves splinters and cracks when nailing it in. I am using the original back panels, which are quite thin and made of particleboard, and I want to avoid completely damaging the back panel. Has anyone had experience with this and can offer tips on how to nail it without causing the panel to break or splinter? Are there specific nails or techniques that have proven effective in maintaining stability?
I appreciate any constructive advice!
Deoren schrieb:
I would recommend using small pins or so-called brad nails instead of regular nails.That might be true for thin back panels, but pre-drilling in particleboard can further weaken it, depending on how the panel was manufactured. I wonder if nailing is the best option for such a thin back panel at all. Perhaps using screws with a small diameter or bonding with construction adhesive would be a better alternative to prevent splitting.
barpanayot19 Jan 2015 12:46janeo schrieb:
I wonder if nailing is really the best option for such a thin back panel.Thanks for the input! Basically, I want to fasten the back panel to keep the shelf stable. I avoided screws because the boards are quite thin (about 3mm (0.12 inches)). Construction adhesive sounds interesting, but I’m concerned it might cause the edges to lift or create problems later if I need to remove it. So I’m a bit unsure.
Is there really no way to use nails without causing the material to fray or split? How do you handle this? I’d also appreciate any material recommendations or technical tips.
Oh wow, I did it exactly the same way – and what can I say? Carefully pre-drill, choose a thin nail, and gently tap it with a small hammer, that’s the secret! 🙂
Sometimes it also helps to apply a bit of wax to the nail – it slides in more easily, and the material doesn’t split as much.
Be confident, it really works great! Good luck!
