Hello everyone, I recently bought an Ikea Brimnes bed and now I’m facing the challenge of how to secure the back panel of the bed frame in a really stable and long-lasting way. The included screws seem quite weak, and I’m concerned that the back panel won’t be properly supported over time. Does anyone have experience with additional fastening options or alternatives to firmly fix the back panel? I’m especially interested in mechanical solutions that are easy to implement and significantly increase the stability of the furniture without damaging it. I look forward to your tips and experiences!
To stabilize the Brimnes back panel, I recommend the following steps: - Use metal angle brackets installed inside the corners. - Add extra screws, ideally countersunk, for better fixation of the back panel. - Pre-drill the holes to protect the veneer. These measures ensure significantly increased stability and prevent later loosening.
Garry schrieb:
A proven method is to additionally secure the back panel from the inside using small wooden battens. Could you please describe in more detail how the battens are attached and what thickness they should ideally have? Is it better to mount them directly onto the back panel or onto the frame timber? How does it look aesthetically – is the mounting visible, or can it be concealed well?
Tomli schrieb:
Could you please describe in more detail how the battens are fixed and what thickness they should ideally have?The battens should be about 10-15 mm (0.4-0.6 inches) thick and approximately 20-30 mm (0.8-1.2 inches) wide, ensuring they are sturdy enough without adding too much bulk. I screwed them directly to the inner back panel where they support the connection to the frame structure. The installation is done on the inside, so it remains completely hidden once the bed is assembled.
You should pre-drill the holes to prevent the wood from splitting. The battens act as additional tension and compression elements, relieving stress from the small original screws.
Garry schrieb:
The battens act as additional tension and compression elements, relieving the small original screws.This is a crucial point. It is often underestimated that with these lightweight pieces of furniture, precise load distribution is essential. Wooden battens significantly reduce the load on individual screws.
