ᐅ Which tools are helpful for repairing Ikea Hemnes furniture?
Created on: 11 Feb 2018 20:03
kofominHello everyone,
I recently repaired some of my Ikea Hemnes furniture and noticed that the appropriate tools are not always obvious. Since Hemnes furniture often uses special fasteners and screws, I want to ask a clear and precise question here:
In your experience, which tools are the most helpful and practical when repairing Ikea Hemnes furniture? Specifically, I’m interested in which screwdrivers (Phillips, flathead, Allen) or other tools are needed to properly handle typical assembly and repair tasks. Are there any special aids or tips that make the process significantly easier?
Thanks in advance for your insights and recommendations!
Tobias schrieb:
For Hemnes, you mainly need a Phillips screwdriver, usually size PH2.I can only agree with that! Here’s a little tip from me: a torque wrench isn’t essential, but if you want everything to fit perfectly without over-tightening, it’s worth having.
Also, it makes things easier if you have some lubricant or furniture sliders on hand, especially if you’re repairing drawers, for example. And yes, a small hammer—preferably with a wooden mallet head—is always useful to carefully put the Hemnes furniture back together 😉.
kofomin schrieb:
From your experience, which tools are the most helpful and practical when repairing Ikea Hemnes furniture?This is a good and especially specific question. The best approach for Hemnes furniture is to first carefully check the original screw connections. Typically, Phillips screws in various sizes are used, often PH2, as already mentioned. Larger slotted screws are rare, and sometimes metal pins and dowels are also used.
From my experience, the following tools are essential:
- Phillips screwdrivers (PH2 and PH1)
- Rubber mallet (for securing parts without causing damage)
- Pliers (for stuck metal pins or nuts)
- Flathead screwdriver (for narrower screws)
Additionally, a small cordless drill with adjustable torque can make the work much easier, especially if you are working on multiple pieces. But be careful not to apply too much force to avoid splitting the wood.
In short: prefer good hand tools, be cautious when tightening screws, and handle wooden parts gently.
