ᐅ Which replacement parts for Ikea BESTA are the most difficult to obtain?
Created on: 17 Jun 2019 09:23
Bevin
Hello everyone, I am currently researching the Ikea Besta system in more detail and wondering which spare parts for this furniture range are the most difficult to obtain. I am especially interested in parts that are not easily available through the standard Ikea service or that, when needed as replacements, are often out of stock or hard to find. It would be helpful if you could share your experiences, for example whether hardware, fronts, screws, connectors, or other components have been problematic for you. Are there any known issues with spare part availability for older Besta versions? I appreciate any tips, especially since I am planning some repairs and want to know in advance where potential shortages might occur.
Bevin schrieb:
Are there any known issues with older BESTA versions regarding spare part availability?Yes, for older BESTA versions (especially those from before 2010), the availability of frame profiles and connecting hinges is significantly limited.
An important tip:
- These frame profiles often have unique slot widths and hole spacing dimensions.
- Spare parts are rarely offered directly by Ikea and are usually only available through third-party suppliers in the DIY sector.
Because of this issue, it is recommended to carefully document the measurements before attempting any repairs and inquire about profiles that match as closely as possible.
Oh yes, spare parts for Ikea BESTA can sometimes be quite a challenge! Especially when you consider how many different versions and generations there are. The most important thing is not to give up 😄
I also once looked for spare parts for the drawer slides – quite difficult. Sometimes it helps to ask directly in the warehouse or even check in the Ikea store itself to see what’s still available. Patience pays off, and then the BESTA system runs smoothly again!
PLOMA schrieb:
The following approach helped me:
- Identifying the year of construction and comparing it with product lists from forums and assembly instructions
- Searching for compatible third-party dampers with similar dimensions and damping characteristics
- Adjusting the brackets using small wooden spacers to securely install the new dampersThank you very much for this detailed explanation. Could you share which sources for third-party dampers have proven reliable? I have often found that many alternatives are inexpensive but not durable in quality. Are there specialized suppliers or workshops that focus on replacement solutions for IKEA furniture?
