ᐅ Which replacement parts are important for Malm furniture?
Created on: 29 Sep 2017 19:12
Paulflo
Paulflo
29 Sep 2017 19:12
Hello everyone, I recently purchased some Malm furniture from IKEA and I'm wondering: which spare parts for Malm furniture are especially important and commonly needed? Especially for drawers, runners, screws, or fittings – are there parts that are easily lost or damaged and therefore best kept as replacements? I would appreciate a detailed assessment, ideally including experiences with which parts tend to wear out or break most often. Thanks!
V
vinpau
29 Sep 2017 19:38
That’s a great question, Paulflo! 🙂 With Malm furniture, the drawer slides are definitely very important. If they break, the drawer won’t operate properly—I know this from personal experience. Especially the small nylon rollers or metal runners used in the slides can wear out or break quickly. So, make sure to get replacement slides or rollers! Also, the small dowel screws that hold the drawers in place sometimes get lost if you dismantle the furniture often. Then there are the small connecting parts like metal brackets or clips, which can sometimes break. It’s best to keep all these parts carefully or buy replacements right away—that will save a lot of trouble later! 🙂
edisondan
30 Sep 2017 07:24
vinpau schrieb:
Especially the small nylon rollers or metal gliders used in the drawer slides can wear out or break quickly.
That is correct. Malm drawers typically use standard slide systems that are durable but subject to wear on the rollers and guide rails. Replacement guides are ideally original IKEA parts, as others may not fit precisely.
Additionally, Malm furniture often uses “Confirmat” screws, which can become worn or lost after repeated assembly and disassembly.
A well-stocked spare parts box should therefore include the following components:
- Drawer slides (including rollers or gliders)
- Connecting screws (Confirmat screws)
- Corner brackets for the carcass
- Plastic stoppers and feet
These parts often allow for repair or reinforcement without the need to replace the entire piece of furniture.
Katau
30 Sep 2017 10:57
I would like to add some practical tips for sourcing spare parts for Malm furniture: It is very helpful to open the packaging of small parts when purchasing or assembling and sort everything accordingly. This way, it is easier to see later which screws or clips are used more frequently or if replacements are needed.
I also recommend going directly to IKEA’s spare parts department or searching online for the specific product number of the furniture parts. There are often detailed lists of available spare parts – including simple ordering options.
The drawer slides with plastic runners are also often a weak point, as they can become brittle or break under load. If the furniture is moved frequently, it is worth keeping appropriate replacement runners in stock.
Finally: screws in the base area are often important, as these tend to require more frequent tightening or replacement due to weight stress.
Merlin
30 Sep 2017 15:03
Spare parts for Malm mainly include the drawer slides and the Confirmat screws. There are rollers for the slides that can be easily replaced. Screws can be quickly lost or broken due to installation errors.
Paulflo
1 Oct 2017 08:41
edisondan schrieb:
A well-stocked spare parts box should therefore include the following components: drawer slides (including rollers or glides), connector screws (Confirmat screws), corner brackets for the carcass, plastic stoppers and feet
Thank you very much for the clear list; it helps me a lot. I’m also curious whether these spare parts vary significantly depending on the specific model – for example, are there versions of Malm drawers with completely different slide systems? Or are the components relatively interchangeable across the various Malm pieces?
Additionally, I’m considering the availability of these parts: could spare part accessibility become an issue if someone has owned Malm furniture for several years? How long does IKEA usually supply spare parts for older product lines?
