ᐅ How can I store Malm drawers in a double row?
Created on: 30 Aug 2023 08:17
karron
karron
30 Aug 2023 08:17
Good morning everyone! I’m planning to organize my IKEA Malm drawer dresser in a double-row arrangement because I really want to create more workspace. The challenge is to stack and place the two Malm dressers both vertically and side-by-side so that they stand securely, remain easily accessible, and ideally still allow for the maximum drawer length to be used.
Does anyone have good ideas or experience with storing Malm drawers in a double-row setup without making the drawers difficult to operate or the structure unstable? I imagine some kind of sturdy frame or connector would be useful, but maybe there are other clever solutions? I would appreciate any tips on proven methods, possible modifications, or alternatives!
kasan
30 Aug 2023 08:53
I see a potential fundamental issue with storing Malm drawers in a double row: stability. While Malm dressers are sturdy, stacking them without a secure connection could quickly create a tipping hazard.
Have you already checked whether IKEA offers appropriate connectors or safety brackets?
karron schrieb:
The challenge is to stack and arrange the two Malm dressers safely side by side and one on top of the other, so they are stable, easy to access, and ideally allow for maximum drawer length usage.
The key points here are “safety and accessibility.” If these cannot be assured, I would advise against the classic double-row arrangement.
anken
30 Aug 2023 09:12
Regarding double-row storage: If the drawers are to be placed in pairs, I would recommend first considering the maximum load capacity, as the upper unit partially supports the weight of the lower one.
In practice, it has proven useful to secure individual furniture elements to the wall or floor with angle brackets to prevent possible tipping moments. Combining this with anti-slip mats can also help stabilize the dressers against each other.
It is also important to consider whether the double width is achieved by placing two dressers side by side or if you actually intend to stack them – this makes a significant difference for drawer accessibility.
PeoDaniel
30 Aug 2023 10:03
Hello karron, I have a setup with two Malm dressers placed side by side, but not stacked.
karron schrieb:
I imagine that some kind of sturdy frame or connection would be useful
That is absolutely correct. I secured my two units together using strong mounting brackets. This makes everything very stable, prevents wobbling, and keeps the drawers aligned. It is important that you also anchor the dressers to the wall, because otherwise the system can tip over, especially if there are children in the house.
If you want to stack the Malm units, you need profile furniture or stacking frames that distribute the weight evenly. Even thick wooden boards placed between the dressers often do not provide good stability but rather pose a risk.
retau
30 Aug 2023 10:36
Oh, that’s great that you want to store the Malm in a double row! 🙂
I’ve read that you can use special “joining strips” or “furniture connectors” for this, which are screwed in on the side.
Another idea would be to place the second dresser on sturdy blocks or a shelf fixed to the wall. This way, you can access the second row at a comfortable height and make great use of both levels!
Very important: Make sure all screws are tightened properly, otherwise it won’t work. This is really a fun challenge!
Palenar
30 Aug 2023 11:19
An important aspect to consider when double-row storing Malm drawers is the distribution of loads on the individual components and their support surfaces.
karron schrieb:
The challenge is to stack and arrange the two Malm dressers both vertically and side by side in a way that ensures they stand securely, remain easily accessible, and ideally still allow full use of the maximum drawer length.
From a technical perspective, the storage solution must meet the following requirements:
1. Structural safety: The lower dresser not only supports its own weight but also the load of the stacked dresser, including its contents. The load limits of the mounting points (brackets, screws) must not be underestimated.
2. Accessibility: Double-row storage often means drawers are placed one behind the other. In this case, the front row should either be fully removable or easily swung out to access the rear row.
3. Assembly and materials: Using high-quality metal brackets or custom-made wooden frames can help enhance stability and simplify assembly.
For implementation, I recommend first taking precise measurements of the dressers and then possibly creating a CAD model or at least a sketch to test different configurations.
