ᐅ Which screws are more durable than the IKEA standard screws?
Created on: 18 Oct 2022 19:43
Latemau
Latemau
18 Oct 2022 19:43
I have a question for the experts here in the forum: Which screws are more durable than the standard IKEA screws when you want to secure furniture or shelves for the long term and ensure stability?
I’ve noticed that the screws often supplied with IKEA furniture tend to wear out relatively quickly after repeated assembly and disassembly or under heavy load – whether due to thread wear, material fatigue, or rust.
I am therefore looking for alternatives that can be used as replacements without having to buy entirely new fittings. I’m especially interested in screws that offer better quality, are more durable, and are suitable for wood or particleboard furniture. Are there specific materials, surface treatments, or screw types that have proven effective?
Tips on the right size and the appropriate drive type (Allen, Torx, Phillips, etc.) that promote long-term durability and a secure connection would also be helpful.
I look forward to your experiences, recommendations, and advice on what to watch for when replacing screws to keep IKEA furniture stable and secure over time.
Thank you in advance!
KARJU
18 Oct 2022 22:07
Basically, IKEA screws are produced for the mass market with cost and assembly efficiency in mind and perform adequately under normal use.
For a more durable solution, I recommend screws made of alloy steel with a zinc-plated or electro-galvanized finish, as these provide significantly better corrosion protection. Stainless steel variants (e.g., A2 or A4) are even more resistant to rust, especially when furniture is placed in more humid environments.
Regarding the screw head, Torx screws are more stable and less prone to wear than the classic Phillips head, as the drive allows for greater torque transfer and experiences less stripping.
If the furniture is mounted in wood or particleboard, screws with specially designed threads suitable for wood should be used (for example, coarse threads for better anchoring). Pan head or washer head screws also generally provide a better fit in the material.
Summary:
- Material: Zinc-plated or stainless steel (A2/A4)
- Screw type: Torx drive
- Thread: Coarse wood thread
- Head: Pan head or washer head
This way, the lifespan can be significantly increased compared to the standard IKEA screw.
fikeo
19 Oct 2022 06:28
Hello Latemau,
I can only agree with KARJU and would like to add the following: The durability of a screw depends not only on the material quality and surface treatment but also heavily on choosing the correct screw size and length.
Some users use screws that are too short, which only hold superficially and may break more easily after repeated assembly and disassembly. The problem is often that screws provided by IKEA are designed to be as cost-effective and universal as possible, which does not always mean optimal durability.
In addition, using stainless steel screws is often the best compromise when the furniture piece might be exposed to moisture, for example in the bathroom or kitchen. Although stainless steel screws are somewhat more expensive than zinc-plated ones, they last significantly longer and do not rust.
For the drive type, I recommend the Torx version because it does not wear out as quickly as a Phillips head when repeatedly screwed in and out.
So if you want to secure your IKEA furniture for the long term, it is better to buy high-quality wood screws with the appropriate material and drive type. One option is to look specifically for "stainless steel wood screws with Torx drive" at a specialty store or hardware store.
One more tip: If you are screwing into particleboard, it can be helpful to drill a small pilot hole before screwing in order to avoid splitting the material and to insert the screw cleanly.
I hope this helps you.
kasan
19 Oct 2022 14:11
KARJU schrieb:
Torx screws are stronger and less prone to wear than the classic Phillips head
I basically agree with that, but it’s important to differentiate how much difference this really makes in practice. There are certainly well-made Phillips screws that are durable if they are made from high-quality steel and have a well-treated surface.
fikeo schrieb:
Stainless steel screws are somewhat more expensive than galvanized ones initially, but they last much longer and don’t rust
That’s true, but you also have to pay attention to the quality of stainless steel. Cheaper stainless steels can sometimes be prone to stress cracking or may be too brittle for certain applications. This is especially important for furniture with moving parts.
Another crucial factor is corrosion caused by “contact corrosion” when stainless steel screws come into contact with other types of metal fittings. This often leads to additional wear due to galvanic effects.
Overall, you shouldn’t just consider the screw by itself but also the interactions with the furniture material and fittings.
So my question to the community: Does anyone have experience with durable screws especially suitable for IKEA furniture, which often combines particleboard and metal fittings? Are there recommended combinations or special types that are durable both mechanically and electrochemically?
