ᐅ How rust-resistant are the metal fittings used in Ikea Metod kitchen systems?
Created on: 18 Nov 2020 08:23
kubeli
I am currently planning a kitchen renovation using the Ikea Metod system and was wondering about the rust resistance of the metal fittings in Metod. Specifically, I am interested in whether the hinges, drawer slides, and other metal parts have sufficient corrosion resistance, especially given that kitchens often involve moisture, steam, and occasional splashes.
Has anyone had experience with the durability of these metal fittings? In particular, I want to know if they remain rust-free over the long term under normal use, or if rust spots tend to appear quickly.
I currently use stainless steel fittings in my old kitchen and would like to understand whether Ikea uses regular galvanized steel parts or higher-quality materials, so I can make a better comparison.
I look forward to your insights, including any background information on the materials used or recommendations for care and protection.
Best regards!
NUPIN
18 Nov 2020 12:45
Great topic! My Metod furniture has been in the kitchen for 4 years now without any rust. I also have a good ventilation system and usually keep the surfaces dry.
If you want to do something extra, you can treat the fittings with a fine spray wax or maintenance spray. This keeps the metal shiny and protected! Good luck with your kitchen renovation.
Lilygla
18 Nov 2020 13:17
Hello kubeli,
In general: The metal fittings of Ikea Metod are mostly made from galvanized steel. The galvanization protects the base material, the steel core, from corrosion by creating a galvanic barrier that shields the metal from oxygen and moisture.
However, every galvanization has its limits. The thickness and application determine the duration of the protection. At Ikea, these coatings are applied industrially, representing standard quality, but they are not comparable to high-quality, thicker galvanizations, for example from specialized hardware manufacturers or stainless steel.
In high-stress areas, such as hinge inner surfaces where abrasion occurs from opening and closing, the protection can wear off more quickly. If moisture then penetrates and does not dry, rust spots are inevitable.
Another factor is the environmental exposure: In kitchens with high humidity, steam, or salt air (e.g., near the coast), the risk is increased. The same applies to cleaning with aggressive cleaners that attack the zinc layer.
I recommend:
- Regular cleaning of the fittings with a mild detergent
- Rinsing and drying the metal parts afterward
- Optional oiling or waxing to refresh the coating
If you can tell me whether the kitchen has strong steam generation or if you have already noticed any water issues around the fittings, I can give you a more precise assessment.
I hope this helps for now!
sarGabriel
18 Nov 2020 13:45
Correct, stainless steel is not used. Galvanized steel is the standard.
kubeli
18 Nov 2020 16:27
Lilygla schrieb:
If moisture penetrates and does not dry out, rust spots are inevitable.
Thank you for the detailed response! That somewhat confirms my concerns. My kitchen produces quite a bit of steam and moisture during cooking. I ventilate regularly, but sometimes it’s difficult, especially when it’s cold outside.
dunitan schrieb:
Could you tell me how your kitchen is currently ventilated?
The kitchen has a window that I usually tilt open while cooking and a range hood that we use regularly. Despite this, moisture has occasionally appeared, including on the walls beneath the countertop.
I will definitely look into maintaining the fittings. Are there specific products suitable for galvanized fittings from IKEA, or is regular oil or wax treatment sufficient? Or should I be careful not to damage the surface?
I’d appreciate any good recommendations.
Khalil
18 Nov 2020 17:05
kubeli, I use a special spray oil designed for household fittings on such metal parts – it’s completely sufficient and provides good protection against rust. It’s important to apply it thinly so it doesn’t build up or become sticky.
I also had issues with rust on Metod hinges in a very humid kitchen once. Since then, I spray a little every quarter and haven’t had any problems anymore. 🙂
dunitan
18 Nov 2020 18:02
kubeli schrieb:
Are there any specific products suitable for galvanized fittings at IKEA, or is common oil or wax care sufficient? Or should one be cautious to avoid damaging the surface?
For maintaining galvanized surfaces, I recommend using mild oils or specific corrosion protection products available at hardware stores. Waxes can hinder the function of moving parts, so it’s better to use oils. I would avoid strongly aggressive agents to prevent damaging the galvanization.
