ᐅ Which repair kits are suitable for minor damage to Ikea BESTA units?
Created on: 26 Oct 2022 17:38
Lotra7
Lotra7
26 Oct 2022 17:38
I have a small issue with my Ikea Besta furniture in my apartment. There are some minor damages – such as small scratches, occasional chipped edges, and light scuffs. I would like to repair these myself in a discreet and lasting way. So, my question is:
Which repair kits or products are specifically suitable for small damages on Ikea Besta furniture? I am not looking for large-scale replacements or professional carpenter solutions, but rather something easy to use for minor repairs like scratches in laminate or damaged plastic edges. It is also important that the color or surface matches the original as closely as possible.
Do you have any recommendations based on your own experience, preferably with advice on application and durability of the kits? Thanks in advance!
lajudo
26 Oct 2022 18:21
I would recommend wood repair wax. It comes in various colors and is easy to apply. Afterwards, smooth it out with a putty knife. Ideal for small scratches and abrasions.
Hector
27 Oct 2022 09:46
I have to disagree a bit here. Ikea BESTA often has a melamine or laminate surface, not real wood. Repair wax may work superficially, but it usually doesn’t last long and rarely matches the color exactly.
In my opinion, repair kits specifically designed for laminate or plastic surfaces are better suited, as they allow for color mixing and sealing afterward. A good option would be kits with acrylic or synthetic resin fillers that cure hard and are more durable.
Have you tried these types of products? How do they perform in terms of flexibility and durability? Some are not UV-resistant and tend to yellow over time.
Layla
28 Oct 2022 14:07
Hector schrieb:
In my opinion, special repair kits for laminate or plastic surfaces are better suited, as they allow for color mixing and then sealing.
I can only agree, as I had similarly damaged BESTA fronts and initially experimented with wax. After a few weeks, it looked unattractive again.
I then bought a kit where you can mix the color to match white or the wood finishes. The sealing is really important – it protects against further wear.
I didn’t find the process difficult to use. It’s best to work in small steps and allow everything to dry thoroughly. If anyone wants, I’m happy to share the exact name of the kit here, as it worked well for me and still looks pretty good after several months.
