ᐅ What mistakes should be avoided when assembling the Ikea Brimnes furniture?
Created on: 7 Mar 2022 19:37
Nostig
Nostig
7 Mar 2022 19:37
I plan to assemble the Ikea Brimnes wardrobe myself, but from experience, small mistakes during assembly—especially with Ikea furniture—can cause many problems later on. Therefore, my question to the community is: What common errors should be avoided when putting together the Brimnes wardrobe to ensure it remains stable, all doors close evenly, and no parts warp? I’m also referring to issues that only become apparent later, such as the wardrobe wobbling or the instructions being somewhat unclear. If possible, please share any tips on tools or methods that can make the assembly easier or improve the quality of the finished product. Thanks!
barda6
7 Mar 2022 20:03
Always sort all parts first and check that nothing is missing or damaged. When assembling, make sure to align the side walls precisely; otherwise, the door will not close properly.
kemeo68
8 Mar 2022 08:49
barda6 schrieb:
When assembling, make sure to align the side panels precisely, otherwise the door will not close properly.
This is a classic issue that often sparks debates about Ikea furniture – why advertise the furniture as easy to assemble when these side panels can frustrate even experts? I would argue that the cabinet is only partially suitable for solo assembly. The assembly instructions are sometimes less than ideal and frequently require awkward postures that increase the chance of errors.
KAMERON
8 Mar 2022 11:14
Some of the most common mistakes when assembling the Brimnes wardrobe include:
- Incorrect positioning of the side panels, which affects stability and door function.
- Careless handling of screws and connectors: overtightening or leaving them too loose can cause warping.
- Ignoring the instruction steps, especially when installing hinges and guide rails.
- Omitting the dowels that are important for connection stability.
My advice: Before assembly, carefully check all parts and screws, and double-check that screws are tightened firmly by hand but not overtightened. Ideally, use a cordless screwdriver with adjustable torque to avoid damage.
Danial
9 Mar 2022 16:27
kemeo68 schrieb:
This is a classic issue that often sparks debates with Ikea furniture – why do they advertise these pieces as easy to assemble when even experts can get frustrated with the side panels?
This criticism is justified, but it’s important to remember that Ikea furniture like Brimnes is a mass-produced product designed to keep costs as low as possible. The instructions are aimed at the average user, not professionals. For this reason, careful planning and patience during assembly are extremely important. You should also consider the material properties of the particleboard used in Brimnes – moisture or incorrect pressure when screwing can cause the material to warp or swell.
My recommendation for everyone is to ideally assemble the furniture with two people, handle the parts carefully, and follow the instructions exactly, even if some steps seem unnecessary. The supposedly simple assembly often requires meticulous precision.
