ᐅ Which materials used in Billy shelves are most prone to damage?
Created on: 3 Aug 2020 11:27
ALBERTBU
ALBERTBU
3 Aug 2020 11:27
Hello everyone, I am currently looking into the common weak points of IKEA’s Billy shelves and would like to find out which materials used in these shelves are most prone to damage. My question is: What factors contribute to the deterioration of the materials used in Billy shelves, and based on your experience, which materials are particularly sensitive to wear, moisture, or mechanical stress? I am interested in detailed assessments, preferably with advice on how to prevent such damage through appropriate measures. Thank you in advance for your expertise!
Nigel
3 Aug 2020 13:02
The particleboard, which most Billy shelves are made of, is the most vulnerable component. It swells quickly when exposed to moisture, significantly losing stability. The edges are usually fragile as well. Screw holes often pull out eventually, especially if the shelves are frequently moved.
TEBILO
4 Aug 2020 07:41
Nigel schrieb:
The particleboard used in almost all Billy shelves is the most vulnerable.
I can only agree with that and would add that the construction of the shelves themselves consists of industrially manufactured particleboard with a thin veneer layer or foil coating. Due to the porosity of this material, the cut edges are particularly poorly protected against water or moisture, causing these areas to swell and deform quickly. This makes the shelves prone to swelling or breaking at the connection points.
Additionally, the thin surface layers on the boards are easily damaged by scratches or impact. Another weak point I see is the back panel, which is often made from very thin hardboard – it lacks the necessary stability, so the shelves can sometimes feel wobbly or unstable under load. How exactly do you use your shelf? Is it heavily loaded or placed in a more humid environment? That could affect which areas are most at risk.
keelko
5 Aug 2020 16:58
TEBILO schrieb:
The thin surface layers on the boards are easily damaged
I’d like to add my two cents here 😉. Sure, the laminated finish on Billy shelves looks nice, but it doesn’t handle rough treatment well. Especially if it gets scratched or bumped, the surface can quickly get marked and look worn.
I also have concerns about the back panel: it’s so thin that I’m always worried whether it really keeps the shelf unit stable, especially when I move it around. Honestly, if you expect strength and protection from Billy shelves, you might be disappointed sometimes. If you’re fond of your shelves, it’s really important to protect them from moisture – I personally use a thin moisture barrier underneath, and since then I’ve had much fewer issues. 🙂
But hey, that’s also why Billy shelves are so affordable and easy to repair. Just replace the damaged boards and keep going! ;-) How do you protect your shelves against potential damage?
