I am planning to upgrade my Ikea Besta shelving unit with LED lighting and am wondering which LED lights work best for the different BESTA models. I am not only concerned with functionality but also with factors such as:
- easy installation on or within the BESTA components,
- a discreet design,
- a pleasant light color that complements the interior,
- ideally dimmable options or control via remote control or app.
Does anyone have good recommendations or practical experience with specific LED lights or kits that are perfectly suited to the dimensions and design of BESTA? Perhaps also special adapters or mounting options to consider?
Looking forward to your suggestions!
MEKRENAR schrieb:
I am planning to upgrade my Ikea BESTA shelving unit with LED lighting and am wondering which LED lights work best for the different BESTA models.Good morning,
to answer your question precisely, it helps to first differentiate the typical lighting applications for BESTA units:
- Interior lighting for display cabinet sections,
- indirect ambient lighting under or behind the units,
- targeted accent lighting, for example, for individual compartments.
For interior lighting, I recommend 12V LED strips, preferably narrow strips with a self-adhesive backing. Brands like Philips Hue Lightstrip or Govee offer easily cuttable strips that can be adapted very flexibly.
Important for installation:
- The strip should be attached to a flat, clean surface. The plastic edges of BESTA units often provide exactly these spots.
- Pay attention to heat buildup, especially with longer strips – a small aluminum profile for cooling helps.
Dimmability and app control are excellently implemented with Philips Hue, which increases convenience.
For indirect lighting, narrow LED profiles that can be mounted on the back of BESTA units are suitable. A modular setup with connector plugs is recommended here to stay flexible.
In summary, flexible 12V LED strips with smart controls or simple dimmers are advisable if you value adaptability and convenience.
If you like, I can also provide advice on choosing power supplies and adapters that perfectly match the BESTA dimensions.
REPITAR schrieb:
For interior lighting, I can recommend 12V LED strips, preferably slim strips with a self-adhesive backing.I agree with that.
Important points for LED lighting with BESTA:
- The length of the strips should be adjusted to the cable routing inside the modules to avoid visible wires.
- For dimmable options, ensure compatibility between the dimmer and the type of LED.
- The color temperature: Warm white (2700-3000K) works best for most living spaces and pairs well with the typical wood or white finishes of BESTA.
I also recommend planning the power supply so that all lights can be controlled centrally. Depending on the intended use, this is more convenient than individual switches on each module.
In short: focus on compatible 12V LED strips, warm color temperature, and centralized power control. For especially high-end solutions, consider branded products with guaranteed quality.
FLOBAU schrieb:
Warm white (2700-3000K) suits most living environments best and pairs well with the typical wood or white finishes of BESTA.Additionally, when choosing LED lighting for Ikea BESTA, it is important to consider not only the color temperature and mounting method but also the light distribution and CRI (Color Rendering Index). Especially for display cabinets or open shelves, a high CRI (above 90) can make the contents appear much more natural and true to color.
For a discreet and visually appealing integration, fixtures with slim aluminum profiles or integrated LED panels are recommended, which can be mounted using magnetic or clip fasteners. These also allow for easy replacement.
If smart control is a priority, choosing products compatible with common systems (Hue, Zigbee, Z-Wave) is advisable to facilitate future expansion.
In summary, selecting LED lighting for BESTA involves a balance of mounting style, light quality, and controllability, tailored to individual needs.
