ᐅ Which Ikea Pax dimensions are suitable for small or tight rooms?
Created on: 21 Nov 2021 19:08
Muta61
Muta61
21 Nov 2021 19:08
I am currently planning to buy an IKEA Pax wardrobe for my rather small bedroom and am wondering: Which Pax dimensions work best for tight spaces? It is important to me that the wardrobe provides enough storage despite the limited space, remains functional, and does not overwhelm the room.
Many IKEA Pax wardrobes come in widths of 50 cm (20 inches), 75 cm (30 inches), and 100 cm (40 inches), with different heights (201 cm (79 inches), 236 cm (93 inches), 271 cm (107 inches)) and depths (35 cm (14 inches), 58 cm (23 inches)). In my room, I only have a corner available with about 80 cm (31 inches) depth and 150 cm (59 inches) width.
I would like to know which combinations of width and depth you would recommend for similarly small rooms to maximize storage space without making the wardrobe feel too bulky or dominant. Are there any experiences with certain depths or wardrobe heights that work better?
Thank you in advance for your tips and recommendations!
puvin
21 Nov 2021 19:27
Great question! 😊 For tight rooms, I often recommend a depth of 35 cm (14 inches) because the cabinet takes up much less space while still providing plenty of storage when you use smart interior features like shelves and drawers.
A width of 50 cm (20 inches) works well if space is limited. It’s better to have several narrow units rather than one large bulky piece – this feels more open and flexible!
Here’s the best approach: measure the space carefully, plan the room in centimeters, and then you can make full use of the available area. Good luck, it will surely work out! 😀
Kenon70
21 Nov 2021 20:04
For small rooms, I recommend a width of 50 cm (20 inches) and a depth of 35 cm (14 inches). You can adjust the height according to the ceiling height; 201 cm (79 inches) is usually sufficient.
SauDietmar
22 Nov 2021 08:16
Muta61, I think your question is very well posed, and here are some specific points you should pay attention to:
- Width: 50 cm (20 inches) is the best compromise for tight spaces, as it’s not too wide but still provides storage.
- Depth: 35 cm (14 inches) is ideal for small rooms, since 58 cm (23 inches) often takes up too much space.
- Height: 201 cm (79 inches) is practical because this height usually fits without problems.
It’s also important how you use the interior space: consider shelves, drawers, or hanging rods. With a depth of 35 cm (14 inches), you shouldn’t hang clothes that are too long, otherwise they may bunch up or the closet may look overcrowded.
A small tip: if possible, build two narrow units side by side instead of one large one – this looks better visually.
If you can use the floor space, low dressers are an alternative for additional storage if your room height is limited.
Good luck with your planning!
paulu
22 Nov 2021 11:52
Short and clear: Pax is 50cm (20 inches) wide, 35cm (14 inches) deep. Height depends on the room, but 201cm (79 inches) usually fits well. It takes up very little space and is still spacious to use.
JAFUHAU
23 Nov 2021 07:38
I think you’re worrying too much – a Pax wardrobe is really versatile. I understand that the space is limited and that makes things uncertain. But with a depth of 35 cm (14 inches), you can still combine a lot of options flexibly.
If you’re concerned that the wardrobe might feel overwhelming, you could consider lighter colors or open doors (mirrored doors) to make the room appear larger.
I once had a small bedroom with a depth of 75 cm (30 inches), which was actually a lot – the room was much tighter. It’s better to have less depth but a smart layout.
