ᐅ Which Ikea Metod cabinets are particularly strong and suitable for heavy loads?
Created on: 18 Feb 2020 14:23
BUSHRAGA63
I am currently planning a new kitchen using IKEA Metod cabinets and intend to store very heavy items in some of the base cabinets and tall cabinets. Specifically, this includes heavy kitchen appliances, large quantities of cookware, and pantry supplies. Therefore, I’m wondering which IKEA Metod cabinets, based on your experience or research, are particularly sturdy and capable of handling such loads.
I understand there are different designs and sizes, for example, 60 cm (24 inches) or 80 cm (31 inches) wide cabinets, with various shelves or levels, but the load capacity of the shelves and the overall construction are crucial. It also matters whether these are tall cabinets or base cabinets, as the construction differs.
Do you have specific recommendations on which cabinets are the most stable? Are there any tips for reinforcing the cabinets or choosing stronger shelves or hanging supports within the Metod system, so that heavy loads of up to 50 kg (110 lbs) per shelf can be safely supported?
I look forward to your insights, experiences, and any practical advice or background information you can share. Thanks in advance!
Landontau20 Feb 2020 08:44I would like to summarize the topic of stability for IKEA Metod cabinets under heavy loads in a structured way:
1. Cabinet Size & Type:
- Tall cabinets offer a more robust frame construction
- 60 cm (24 inches) width is more stable than wider versions (80 cm / 32 inches and above tend to sag)
2. Shelves:
- Standard shelves made of 16 mm (5/8 inch) particleboard have limited load capacity
- Recommendation: EKBACKEN solid wood shelves (22 mm / 7/8 inch) or MDF boards with at least 18 mm (3/4 inch) thickness
- For heavy loads, use center supports or additional metal brackets
3. Wall Mounting:
- The weakest point in the system
- Use strong metal brackets with multiple screws
- For loads over 30 kg (66 lbs), ensure generous use of wall fixings and check the wall’s load-bearing capacity
4. Interior Fittings:
- Metal drawer runners with high-quality slides distribute weight better than individual shelves
5. Load Distribution:
- Distribute weight as evenly as possible
- Avoid point loads
6. Stability Reinforcement:
- If possible, install interior shelves as additional reinforcement
- Also check feet and cabinet joints; if necessary, reinforce with extra screws or metal brackets
Conclusion: The best stability for heavy loads is achieved by combining 60 cm (24 inches) wide tall cabinets, reinforced shelves, and secure wall mounting.
If anyone is interested, I’m happy to provide examples or tips for installation.
2. Shelves:
3. Wall Mounting:
- Avoid point loads
