ᐅ Which Ikea Metod cabinets are particularly strong and suitable for heavy loads?
Created on: 18 Feb 2020 14:23
BUSHRAGA63
BUSHRAGA63
18 Feb 2020 14:23
I am currently planning a new kitchen using IKEA Metod cabinets and intend to store very heavy items in some of the base cabinets and tall cabinets. Specifically, this includes heavy kitchen appliances, large quantities of cookware, and pantry supplies. Therefore, I’m wondering which IKEA Metod cabinets, based on your experience or research, are particularly sturdy and capable of handling such loads.
I understand there are different designs and sizes, for example, 60 cm (24 inches) or 80 cm (31 inches) wide cabinets, with various shelves or levels, but the load capacity of the shelves and the overall construction are crucial. It also matters whether these are tall cabinets or base cabinets, as the construction differs.
Do you have specific recommendations on which cabinets are the most stable? Are there any tips for reinforcing the cabinets or choosing stronger shelves or hanging supports within the Metod system, so that heavy loads of up to 50 kg (110 lbs) per shelf can be safely supported?
I look forward to your insights, experiences, and any practical advice or background information you can share. Thanks in advance!
Donar34
18 Feb 2020 15:11
In general, the IKEA Metod cabinets with a width of 60cm (24 inches) are the most stable for heavy loads, as larger cabinets (80cm (32 inches) and wider) tend to show more sagging when fully loaded. Tall cabinets are generally constructed to be more stable than base cabinets because they have a stronger frame and are often combined with steel reinforcements.
Regarding the shelves, I highly recommend replacing the standard chipboard shelves with the IKEA reinforcement boards made of MDF, which have a higher load capacity. According to the manufacturer, each shelf can support up to 25-30 kg (55-66 lbs), and with multiple reinforcements and the additional installation of center supports, even higher loads are possible.
For very heavy loads of up to 50 kg (110 lbs) per shelf, it is definitely necessary to add extra wall mounting reinforcements and possibly install reinforced brackets. It is best to replace the fixing elements (dowels, screws) with stronger versions to prevent deformation and tipping.
In summary:
- Prefer tall cabinets with a width of 60cm (24 inches)
- Use reinforced MDF shelves
- Plan for additional wall mounting and brackets
This combination reliably withstands heavy loads.
Parbo
18 Feb 2020 17:45
In my view, it is especially important to consider the exact type of load: Does the shelf carry the weight evenly distributed, or are there point loads? This greatly affects stability.
Donar34 schrieb:
For very high loads of up to 50 kg (110 lbs) per shelf, you should definitely add extra reinforcements to the wall mounting and possibly use reinforced brackets.
I believe this is the crucial point: the wall mounting is often the weakest link, because the cabinets themselves can handle a lot, but if the anchoring is not strong enough, cracks can quickly form in the wall or in the cabinet frame.
I have worked with several IKEA Metod cabinets and recommend replacing or supplementing the metal brackets supplied by IKEA with sturdy, preferably screwed brackets from a hardware store, using at least 3–4 screws per side.
When choosing shelves, you should also consider using MDF boards with a thickness of at least 18 mm (0.7 inches) and adding a center support if the width exceeds 60 cm (24 inches).
For base cabinets, the load capacity also depends on whether an interior shelf is installed. This helps stabilize the cabinet frame. If you plan to carry very heavy loads, check whether the interior shelf is in place.
Finally, a tip: cabinets with full-height back panels are more stable than those with smaller back wall sections. This aids in distributing the load and prevents deformation.
If you have more specific questions about load distribution, feel free to clarify.
bujufa
19 Feb 2020 09:13
BUSHRAGA63 schrieb:
Are there any tips for reinforcing or selecting stronger shelves or hangers within the Metod system to safely support heavy loads of up to 50 kg (110 lbs) per shelf?
Some time ago, I remodeled a kitchen using Metod cabinet modules and worked with similar load requirements. Here is my practical advice:
- Replace shelves with IKEA EKBACKEN 22 mm (7/8 inch) solid wood shelves instead of standard boards
- Always reinforce the base cabinet frame with metal legs if heavy loads are expected in the lower cabinet
- Equip tall cabinets with solid wood pull-outs inside, as these are often sturdier and securely carry heavy loads
- For large cabinets, use strong wall mounting points and pay close attention to the wall structure (e.g., concrete, drywall)
These measures noticeably improve stability, especially if you want to store heavy kitchen appliances or containers. Avoid placing loads only at the back; try to distribute them evenly.
If you want, I can also share details on installing the EKBACKEN shelves.
GiRoyce
19 Feb 2020 11:08
As an additional note, the type of interior fittings also plays a significant role in the load-bearing capacity of Metod cabinets. Drawers or pull-outs with metal sides are often more durable than standard shelves, provided they are installed with high quality.
Furthermore, the following tips can help:
- Distribute heavy loads across multiple levels
- Avoid point loads, such as very heavy appliances placed on a single shelf
- Use extra shelves to spread the weight
bujufa schrieb:
Don’t place loads only at the back; try to distribute them as evenly as possible.
This is very important because especially the front corners can suffer quickly if loads are not balanced.
Additionally, the load limit of about 25 kg (55 lbs) per shelf segment should generally not be exceeded permanently.
If you need to store very heavy items, consider using additional custom supports or reinforced shelves.
Ritaba
19 Feb 2020 15:27
Just briefly: 60cm (24 inches) wide tall cabinets are sturdier than wider cabinets and also strengthen the wall mounting. Use MDF shelves with a thickness of 18mm (0.7 inches). Avoid point loads.
