ᐅ Which IKEA components fit best inside Pax wardrobes?
Created on: 4 Nov 2018 09:37
jay52
jay52
4 Nov 2018 09:37
I want to achieve the most efficient use of the interior space of my Ikea Pax wardrobe. Therefore, I am particularly interested in which Ikea components or elements are best suited to make the inside of a Pax wardrobe not only functional but also space-saving and flexible. Recommendations for drawer inserts, shelves, hanging rods, or other practical interior fittings that work well with Pax would be especially helpful. If anyone has experience with modifications or custom solutions within the Pax system, I would also like to know how the components perform in terms of stability and everyday usability. Which combinations work best, and from your perspective, what are the advantages or possible drawbacks?
CORYGAU
4 Nov 2018 15:29
An interesting starting question you have there! However, I must point out right away that "optimal" is very subjective. What is perfect for one person might seem completely impractical to another. This should be considered when comparing different Pax interior components.
jay52 schrieb:
Which Ikea components or elements are best suited to make the interior of a Pax wardrobe not only functional but also space-saving and flexible?
On this point, it is clear to say: the drawer inserts are great, especially when it comes to neatly storing smaller items and organizing the space effectively. However, you should also pay attention to the height and width of the compartments, which are sometimes quite fixed at Ikea, limiting flexibility.
jay52 schrieb:
If anyone has experience with modifications or custom solutions within the Pax system, I would also be interested in how the components perform in terms of stability and everyday practicality.
Here, I recommend favoring the original elements, as third-party providers often cannot match the fit and material thickness. This can quickly affect stability negatively. Overall, you have to weigh your options: do you want maximum adaptability or the highest material quality? Compromises are hardly avoidable.
PRA64
5 Nov 2018 10:13
I can relate very well to this topic, as I have set up several Pax wardrobe systems myself. Here is a structured overview of my experience to specifically answer your question:
- Drawer inserts: The VARIERA drawer inserts are excellent for organizing small accessories or underwear. They are easy to install and can be flexibly expanded.
- Clothes rails: The Pax clothes rails are height-adjustable, which is a big advantage for long coats or shorter shirts. For half-height wardrobes, I recommend installing double rails to make better use of the space.
- Shelves: I generally recommend dividing the interior with several shelves. Thanks to the pre-drilled holes in the Pax frame, you can position these precisely.
- Drawer organizers: Internally, there are many options, such as partitions or additional compartments. These greatly improve organization.
Common mistakes I notice are:
- Overfilling the wardrobe space: It is better to prioritize storage.
- Failing to fine-tune the height spacing of the components.
In conclusion, the flexibility is especially evident when combining drawers, shelves, and clothes rails. Would you like further explanations on any of these points or assembly tips?
Laukau5
6 Nov 2018 18:07
To explore the topic in more detail, I would like to highlight some technical aspects and practical experiences that are often overlooked:
First, it is important to know the exact dimensions of the Pax frame and the module sizes of the interior components. Most shelves and drawer units come in fixed depths (e.g., 35 or 58 cm (14 or 23 inches)) and widths (50 or 75 cm (20 or 30 inches)). For optimal use of space, precise measurements before planning are essential, and it is important to avoid fitting larger compartments unnecessarily tightly with small items.
Furthermore, the question of stability is particularly important here: The original drawer slides feature ball bearings and are well suited for the relatively heavy weight of clothing and household items. Third-party accessories often do not offer the same durability and may wear out faster with frequent use.
Regarding the clothes rails, the frame-integrated models are more stable because they are mounted directly in the side profile, compared to simple rods that are only inserted into wall brackets. A small tip: If the wardrobe is located in a particularly humid environment, using rust-resistant rails and fittings is recommended.
For my personal planning, I have always used a 64 mm (2 ½ inch) grid to ensure accurate positioning of the interior fittings. This standard helps maintain compatibility between accessories and reduces the risk of misalignment or improper fit.
To conclude, my question to you: What individual challenges do you currently see with your Pax system? Are you looking to optimize storage mainly for outerwear, shoes, or mixed contents? This will help provide more targeted suggestions.
