ᐅ What type of foundation is suitable for a prefabricated garage?
Created on: 20 Feb 2019 14:30
Golfi90
Golfi9020 Feb 2019 14:30
Hello everyone!
I am planning a prefabricated garage from the company Garagenrampe for our house.
Apparently, there are two options for the foundation of this garage.
One option is a concrete slab foundation, and the other is strip foundations.
Which option would you choose?
Is it better to have a full slab poured and then lay tiles on top?
Or would you go for strip foundations and then pave around the garage?
Musketier20 Feb 2019 15:22
We had a ring foundation installed for our 50m² (538 sq ft) double garage and then paved over it.
The local garage dealer nearby (just search for Garagen Klaus) has tiles in his garage and always has to push puddles out with a squeegee. It also creates a slipping hazard. In my garage, moisture from the car in winter can drain downwards. On the other hand, moisture can seep in through the paving edges during heavy rain, so you should avoid placing wooden shelves directly on the pavement. When sweeping, tiles do have their advantage again.
A small tip on the side: since your garage dealer has all those rims and sleds hanging on the wall, ask for prices for the different hanging solutions and what can be hung up. You can’t just hang things directly on the sheet metal because it’s too thin. So, you’ll need special hanging options. They make their money with all those special brackets.
lastdrop20 Feb 2019 15:47
What I would do in your case doesn’t necessarily have to be right; it could even be wrong. Everyone has their own priorities and preferences [and budget].
As long as the requirements are unknown, it’s difficult to give any advice…
11ant20 Feb 2019 16:21
What is the garage made of, and is it intended only for an everyday car with some extra storage?
My garage for such purposes is made of steel and sits on interlocking paving stones. It is rented—if it were owned, I would be a bit more design-oriented—but it fully serves its purpose as is.
Golfi9020 Feb 2019 16:28
This is a steel wall garage that has been plastered, giving it the appearance of a solid garage.
It is designed to accommodate two cars.
O
Obstlerbaum
20 Feb 2019 16:35
Golfi90 schrieb:
Is it a good idea to pour a full slab and then lay tiles on top?
Or would you choose strip footings and then pave the garage?
I’m not familiar with this concept – doesn’t the garage have a floor?
